VRRP between Cisco 878 and Cisco 876
hitesharora
Hi ,
I have two Cisco routers 878 and 836 with "flash:c870-advipservicesk9-mz.124-6.T2.bin" and "flash:c836-k9o3s8y6-mz.123-8.T9.bin"
My problem is If I configur Standby group 99 priority 110 or vrrp 1 priority 110 on Cisco 878 I lose the secondary Router for ever .....I have tried Pririty 200 for Primary no luck.I have tried pririty 80 for secondary keepping Primary Default as 100.but no luck .I took off all the access list and Crypto from VLAN 1 and eth0 of secondary.Still the same situation.PLEASE HELP
The configuration for the two routers is pasted below :
rajivrajan1
Level 3
Level 3
what do u mean by loosing standby router?
Is Vip up?
can u post any debugs after changing priority
By losing i mean the secondary router becomes unreachable.The telnet session through Putty becomes unresponsive.The VIP is not up .The two router keeps on negoitating with each other .The two routers are 878 and 836 and not 876 as mentioned in the message .Debug messages i will post shortly
gokula_chandran
Could you please check the physical ip of Ethernet0, it should be 192.168.12.3 right?
