VRRP-E, dos the ISR-4K support this?
norberto.padin
Hello team, I'm in an RFP and they are asking for VRRP-E, which is an enhanced version of VRRP.
"The most important difference between VRRP and VRRP-E is that all VRRP-E routers are Backup routers; there is no Owner router. VRRP-E overcomes the limitations in standard VRRP by removing the Owner."
Does IOS-XE (ISR-4k and ASR-1K) support VRRP-E?
Feature navigator only mentions VRRP but the Enhanced version.
Thanks in advance for any input on this.
Nor.
mvsheik123
Level 7
Level 7
Looks like on Brocade & Hpe.. This is what I came across.."Brocade and HPE offer VRRP-E, an extended and proprietary version of VRRP".
hth
MS
