VS-S720-10G-3C on 7600?
quinlanmp
Ok, I am pretty far out of my comfort zone here but these VS-S720-10G-3C cards were purchased to upgrade our 7609/7606 routers, the spec sheet says they are compatable but I can't find an IOS that "likes" them. I had no problem finding an IOS and using the vss cards in our 6506...
Spec Sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/product_data_sheet0900aecd806ed759.html
Any help would be greatly appreciated.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The spec sheet might be mistaken.  I don't believe that sup is supported on 7600s.  If you have a Cisco support contract, it's a question you might bounce off TAC.  Otherwise, we'll see if anyone describes this sup is known to work in a 7600 chassis.
Thanks for the replay...that is kinda the same conclusion I came to...
Wasted a ton of money due to faluty literature!
The Sup-720-VS was designed for VSS and it is only supported on the 6500 series.
