vsat communication on cisco router through c& ku band modem with link failover
vishal4444
it is vsat connectivity..........and we have 40 sites..................
& every site having two modem one c band & another is ku band & also one cisco router.......every  wan is coming through modems to switch >>>>to router fe ports.............pls see the diagram & details //////////  suggest me for better solution
In this scenario we have two remote sites (remote  side 1 & remote side 2) which is connecting on IP GATEWAY .
Working style of modem:-
They are using c band modem & ku band modem (supports Rip V2).One end of both the modem is connected to switch & another end is communicating over satellite freq  with hub BASED IP GATEWAY.
I
Requirement for every site...........
1.If packet is going through wan1 then return path should be wan 1.  If forward path is wan 1 then return path should be wan1. Remote side 1 to remote side 2 communication is given below.
2.Means  remote side 1 cband modem  >>>>>>huB BASED IP GATEWAY ) >>>>then it is going on remote side 2 c band>>>& reverse     should be in the same band means C band....
3. i would like all the video & data traffic translated to c band & in case of primary link  down C band traffic  should be  translated on KU band.
FOR VIDEO & DATA,  PRIMARY BAND IS C BAND & KU BAND IS SECONDARY.
4. In case of voice , i would like all the voice traffic translated to the Ku band  & during primary  link down KU band traffic should be translated on C band.
For voice , KU Band is primary & C band is secondary.
5.C band  is working in star topology  (hub & spoke)& KU band  is working in mesh topology.
In this figure, example is given for star.
Diagram attached.
Hello Vishal,
you can move some steps further in order to improve the solution:
first of all, if VOIP IP subnets are well known and distinct from data vlans you don't even need PBR:
you can use offset-list in a smart way so that Ku band link is the better link for VOIP to VOIP traffic.
hint: you need to use two different access-lists to be invoked under router rip for interface to Ku band and interface to C band
router rip
offset .....
offset ....
QoS is needed so you need to mark traffic inbound  on the LAN interface and to appy appropriate scheduler on the WAN interfaces to ensure a better treatment to VOIP traffic over data traffic
Hope to help
Giuseppe
5 Replies 5
Giuseppe Larosa
Hello Vishal,
you can use RIPv2 with the satellite modems it supports classless routing. It is not very fast in convergence and it has a limit of 15 router hops in the path.
To achieve your requirements you just need to run RIPv2 making the C-band modem preferred.
You can use offset-list on the KU band link in order to make it less attractive for all traffic.
see
http://www.cisco.com/en/US/docs/ios/iproute_rip/command/reference/irr_rip.html#wp1012347
In order to satisfy points 2, 3 of your requirements the offset-list is applied inbound on the FE inteface facing the KU modem in all routers of all POPs including central site.
A PBR rule can divert VOIP packets (both bearer voice payload and voice related signaling) over the KU band link.
Marking the voice packets inbound on internal LAN interfaces allows for the use of queueing, LLQ  is required
PBR:
http://www.cisco.com/en/US/docs/ios/iproute_pi/command/reference/iri_pi1.html#wp1015665
note: if there are security concerns for sending data over the air you should look at DMVPN
to deploy an appropriate mesh of GRE tunnels protected by IPSec this might require more powerful routers
see
http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns816/landing_overall_wan.html
Hope to help
Giuseppe
Sir,
     Thanks for Ur reply.
1. I think ,first of all ,we should used ripv2 on all the network .
2. pbr will be used for the voice ,video over wan 1 (primary)& wan2 secondary  &   for data wan2 will be primary (wan1
will be secondary)
one route map on fe interface
set ip next hop wan1
or set ip next hop verify-ava wan1
We are using 1841 router on all the sites................having  2 ge port &one fe port...............
Please find the configuration ..............  Given Below ...............& if there is any mistake please confirm me.
Current configuration : 1213 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
no ftp-server write-enable
interface FastEthernet0/0
ip address 13.13.13.2 255.255.255.0
shutdown
duplex auto
speed auto
interface FastEthernet1/0
ip address 11.11.11.1 255.255.255.0
ip policy route-map data
duplex auto
speed auto
interface FastEthernet2/0
ip address 12.12.12.2 255.255.255.0
duplex auto
speed auto
router rip
version 2
network 11.0.0.0
network 12.0.0.0
network 13.0.0.0
ip http server
no ip http secure-server
ip classless
access-list 101 permit ip 11.11.11.0 0.0.0.127 any   (for 1 to 126 ip)
access-list 102 permit ip 11.11.11.128 0.0.0.127 any  (for 129 to 254 )
route-map data permit 10
match ip address 101
set ip next-hop 13.13.13.1
set ip next-hop verify-availability
route-map data permit 20
match ip address 102
set ip next-hop 12.12.12.1
control-plane
Hello Vishal,
router rip
offset .....
offset ....
Hope to help
Giuseppe
Sir,
First of all Thanks For ur great reply.
  Please see below.. And 2nd  thing i want high convergence during failover .
If my voice call is running & ku band will be down then it should be translated to c band with minimum time means call should not be disconnected (real time application ..)..& same should be c band to ku band......Offset list will resolve this ..or not  or  i should use the ipsla for the same ...
I want high convergence .......
please see my configuration  & what ll be the offset list & access list for the same ..
pls tell me some idea..
My wan 1 is
shutdown
duplex auto
speed auto
& wan 2 is
duplex auto
speed auto
and local lan is
duplex auto
speed auto
And access list is
access-list 101 permit ip 11.11.11.0 0.0.0.127 any   (for 1 to 126 ip) for data video  c band primary & ku band secodandry in case of failover
access-list 102 permit ip 11.11.11.128 0.0.0.127 any  (for 129 to 254  & for  voice ku band  is primary & c band will be secondary in case of link failover .
waiting for ur reply.
Vishal
9310253052
vishal4444
vishal kumar 2 posts since Jul 29, 2011
Sep 2, 2011 4:40 AM
I
Diagram attached.
