09-08-2011 01:00 PM - edited 03-04-2019 01:32 PM
2 No's 6509 in VSS mode when i try to reboot them they dont come back again to normal state instead they go in rommon, i have specified the boot system flash command with sup-bootdisk: as well as bootflash: but no output.Below is the sh version
sh version
Sep 8 10:12:23.349: %SYS-5-CONFIG_I: Configured from console by console
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI4a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 16-Jul-10 19:51 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
SW1 uptime is 1 day, 4 hours, 12 minutes
Uptime for this control processor is 1 day, 4 hours, 14 minutes
Time since MOFT_CR_SW01 switched to active is 1 day, 1 hour, 58 minutes
System returned to ROM by Stateful Switchover at 10:56:03 GMT Tue Sep 6 2011 (SP by power-on)
System restarted at 10:01:47 GMT Wed Sep 7 2011
System image file is "sup-bootdisk:s72033-ipbasek9-mz.122-33.SXI4a.bin"
Last reload reason: VSLP HA role change from active to standby
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC1443004K
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
13 Virtual Ethernet interfaces
102 Gigabit Ethernet interfaces
36 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
the command what i specify is below:
boot system flash sup-bootdisk:s72033-ipbasek9-mz.122-33.SXI4a.bin
09-08-2011 01:23 PM
Just to make sure. Did you save the config after applying the boot variable command?
can you also mahe sure this is the only boot variable command?
Reza
09-08-2011 02:14 PM
yes i save the config, and i m sure abt the boot variable by sh bootvar command
09-14-2011 02:11 PM
Hello Experts,
any hints OR any perfect IOS upgrade that will make stabilty of 2 Core switches
09-14-2011 03:12 PM
We tried reloading a VSS pair one at a time and one will go into ROMmon and the other will "wait" for the first one to come up. The only way out was to reboot both of them simultaneously.
In disgust, we upgraded to SXJ1 and it seems to work better than SXI4a and we also found the J1 to be more "responsive" or snappier than the I4/I4a.
09-14-2011 03:31 PM
thanks for the reply dear, i will try and i will post back.
