VSS question?
anam.rahman
I have two Cisco 6500 switch in VSS mode in distribution layer and 2 in core layer. My question is how would I know which physical switch is switch 1 and which one is switch 2? If one switch is in standby mode, does this switch intertain any frames coming from/to access layer switch or packets coming from/to core layer.?
VSS-Distro-6K#sh switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 30
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
Leo Laohoo
Switch ID 1 is the Active.
You can also use the command "sh redundancy".
