VTP between ROUTER and SWITCH does not work
Didier1966
Sorry for my newbie question, but to prepare myself for some CCNA courses in October I made a small setup to try a router on a stick ,this work as expected but ....
In the CISCO 1841 (router) , you can setup VLANS and VPT as SERVER and in my CISCO 2950 (switch) as client:
I expected that if both are on the same domain with the same password and everithing that it will work , I mean by work , when I setup the VLAN DATABASE in the ROUTER that he will send it to the switch , but unfortunatly this does not work.
Just for the fun I created in a other switch a VLAN DATABASE (has a SERVER) and this was dumped directly in the CISCO 2950 , so I know that the CISCO 2950 is workin and able to receive VPT.
Any idea why it does not work from the router ?
It is not urgent , it is just for my personal knowledge
Best Regards,
Didier
Router#sh run
Building configuration...
Current configuration : 2303 bytes
version 15.1
hostname Router
boot-start-marker
boot system flash c1841-advsecurityk9-mz.151-3.T2.bin
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.40.1
ip dhcp pool VLAN1
   import all
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
ip dhcp pool VLAN10
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip dhcp pool VLAN20
   import all
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
ip dhcp pool VLAN30
   import all
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
ip dhcp pool VLAN40
   import all
   network 192.168.40.0 255.255.255.0
   default-router 192.168.40.1
ip cef
license udi pid CISCO1841 sn FCZ1217905C
archive
log config
  hidekeys
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
line con 0
speed 115200
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
Router#
Router#
Router#
Switch#sh run
Current configuration : 1152 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
no ip domain-lookup
ip host R1 192.168.1.1
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport access vlan 30
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
switchport mode trunk
interface FastEthernet0/12
interface Vlan1
ip address 192.168.1.254 255.255.255.0
no ip route-cache
ip http server
line con 0
password cisco
login
speed 115200
line vty 0 4
privilege level 15
password cisco
login
line vty 5 15
login
end
Switch#
Switch#
Switch#
Peter Paluch
Hello Didier,
While the 1841 router supports VTP commands, they are effective only if you install a switching module (such as HWIC-4ESW) into the router's WIC slots, and they apply only to switchports on this switching module. Routers do not speak VTP on their routed onboard ports - because for VLANs on these routed ports, you create subinterfaces directly. That is why the VTP does not seem to work between your router and the 2950 switch.
Best regards,
Peter
Peter Paluch
Hello Didier,
Best regards,
Peter
Hello Peter,
Thank You for your prompt reply.
How can I learn this kind of tricks , when you use VPT , CISCO or the IOS do not tell you this , maybe in a next release we will have a message
Thank You Again.
Best Regards,
Didier
Hello Didier,
Thank you! About learning these tricks... well, it's simply practice. I've been working with Cisco devices since 2001. Don't worry, you will learn these things soon enough, and in the meantime, these forums are exactly what should save you the hard try-and-fail way of doing things. Feel always welcome to come and discuss any topic you might have!
Best regards,
Peter
5 years later cisco has got a same issue...
I'm still interested how possibe to pass trough the VTP information between router and switch.
e.g. router 2901 has got 3 Gi port, 1 internet, another 2 1-1 switch eg 3560 without hard-wiring together the 2 switch.
may VPN? or tunnelling?
