VTP Mode Not Working
brijendrasaini
Dear Team,
I am just try to imlemnt VTP moder but clinet not taking data from server configuration as below :
Current configuration : 1057 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 192.168.0.1 255.255.255.0
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#show vlan
Switch#show vlan
VLAN Name Status Ports
1 default active Fa0/2, Fa0/3, Fa0/4, Fa0/5
Fa0/6, Fa0/7, Fa0/8, Fa0/9
Fa0/10, Fa0/11, Fa0/12, Fa0/13
Fa0/14, Fa0/15, Fa0/16, Fa0/17
Fa0/18, Fa0/19, Fa0/20, Fa0/21
Fa0/22, Fa0/23, Fa0/24
20 dc_indore active
30 dc_2 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
20 enet 100020 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
Switch#
Switch#
Switch#show vlan
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
Remote SPAN VLANs
Switch#show vt
Switch#show vtp s
Switch#show vtp status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 255
Number of existing VLANs : 5
VTP Operating Mode : Client
VTP Domain Name : ahel
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x0A 0x30 0x15 0x9D 0xA0 0x34 0x2E 0x02
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Switch#
Switch#
Second Swith i make it Client but no information is passing why i m not undersatnding .
Brijendra
10 Replies 10
Seb Rupik
Hi there,
Your first switch is still int VTP mode client. You need to configure it as the vtp server:
vtp mode server
You should also take the opportunity to configure a VTP password too, to prevent rogue VTP servers flattening your network.
Once 'Switch' has been made a VTP server, the 'second switch' as a client should update its VTP database.
cheers,
Seb.
Switch One :-
server#show vtp
server#show vtp
% Incomplete command.
server#show vtp st
server#show vtp status
VTP Version : 2
Configuration Revision : 2
Number of existing VLANs : 7
VTP Operating Mode : Server
MD5 digest : 0xBC 0xEB 0x35 0xF3 0xB7 0xC9 0xA7 0x14
Configuration last modified by 192.168.0.1 at 3-1-93 00:29:52
Local updater ID is 192.168.0.1 on interface Vl20 (lowest numbered VLAN interface found)
server#
Swich two :-
Switch>
Switch>en
Switch>enable
Switch#show vt
Switch#show vtp
Switch#show vtp st
VTP Version : 2
Switch#
What is the switchport configuration between the two switches? Is it a trunk link?
Brijendra
Can you post the output on both switches of the command
show cdp neighbor detail
Rick
Rick
Hi Richard Sir,
Switch>en
Switch>enable
Switch#show
Switch 1
Switch#sho in
Switch#show cdd ne
Switch#show cdp ne
Switch#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
server Fas 0/1 149 S 2950 Fas 0/1
Switch#
Switch Two
server>en
server>enable
server#con
server#conf
server#configure
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line. End with CNTL/Z.
server(config)#exit
server#
%SYS-5-CONFIG_I: Configured from console by console
server#show in
server#show cdp
server#show cdp n
server#show cdp neighbors
Switch Fas 0/1 165 S 2950 Fas 0/1
Thank you for the output. What you gave me was output of show cdp neighbor and what I requested was output of show cdp neighbor detail.
Rick
Rick
Dear Sir,
Same i perform in Packet tracker it is working now m facingthe issue that is live switch deatils i m pasting below :-
EH_NSK_BSMT_CORE_1#show vtp status
VTP Version capable : 1 to 3
VTP version running : 1
VTP Domain Name : cisco
Device ID : 7426.ac25.d300
Configuration last modified by 10.40.139.194 at 0-0-00 00:00:00
Local updater ID is 10.40.139.194 on interface Vl1 (lowest numbered VLAN interface found)
Feature VLAN:
Maximum VLANs supported locally : 1005
Number of existing VLANs : 11
MD5 digest : 0xC2 0x5C 0xE9 0x36 0x70 0x84 0x94 0xD0
0x20 0xC8 0x8C 0xD2 0x2E 0x33 0x18 0xD2
*** MD5 digest checksum mismatch on trunk: Gi0/8 ***
*** MD5 digest checksum mismatch on trunk: Gi0/24 ***
EH_NSK_BSMT_CORE_1#show vla
EH_NSK_BSMT_CORE_1#show vlan
1 default active Gi0/10, Gi1/1, Gi1/2, Gi1/3, Gi1/4
10 BIO_EQUIP active
20 SERVER active Gi0/14, Gi0/15, Gi0/16
30 UNUSED active
40 USER_NON_INT active Gi0/9, Gi0/12, Gi0/13, Gi0/20
50 USER_INT active Gi0/11, Gi0/18, Gi0/19
53 DC_NSK active Gi0/17
10 enet 100010 1500 - - - - - 0 0
40 enet 100040 1500 - - - - - 0 0
50 enet 100050 1500 - - - - - 0 0
53 enet 100053 1500 - - - - - 0 0
Remote SPAN VLANs
Switch Two
EH_NSK_BSMT2_FLR_01#show vt
EH_NSK_BSMT2_FLR_01#show vtp st
EH_NSK_BSMT2_FLR_01#show vtp status
Device ID : 580a.2004.d480
Feature VLAN:
Number of existing VLANs : 10
MD5 digest : 0x37 0xAF 0x18 0x85 0xB6 0x9C 0x1B 0xBC
0x65 0xB4 0xF5 0xBA 0x4C 0x9B 0xEA 0xE8
*** MD5 digest checksum mismatch on trunk: Gi1/0/24 ***
Ya sir it is trunk link.
Hello
Are these trunks or L3 interfaces?
Show interface Trunk
NOTE:
They need to be trunks, and if they are and your trunks are up and allowing all vlan tor traverse that trunk, Then I  suggest you create an addtional vlan on the server to initate Vlan Memebership Anouncement (VMA) messages and test again.
switch1
conf t
vlan 500
exit   <------------ this is important need to type exit for the vlan to applied
res
Paul
Kind Regards
Paul
Julio E. Moisa
You need to enable trunk mode between switches, verify the domain, password and also check the version, you can use these commands:
trunk example:
interface g1/1/1
switchport trunk encapsulation dot1q  (new switches have it implicit, so you can omit it)
no shutdown
show interface trunks
show cdp
show vtp status <-- here you will verify the mode, domain, version and revision.
show vtp password (check if you have not left any space at the end of the password)
Everything must match
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
