11-03-2006 03:19 PM - edited 03-03-2019 02:34 PM
Hi, I have a 1841 router. And I have a VWIC2-1MTF-G703. The router doesn?t recognize the interface card. The IOS is: c1841-ipbase-mz.124-1c.bin. When I do a sh run, i can?t see the controller E1 neither serial 0, but when I do a sh version, I can see:
1 Channelized (E1 or T1)/PRI port
I need to know if i need an ios upgrade.
IS THIS COMPATIBLE WITH THE 1841?
i HOPE YOU CAN HELP ME
11-03-2006 08:02 PM
This module is definitely supported on 1841 router. Appears, you need to upgrade the IOS to an IP Plus image to support this module.
Excerpt from the below link:
Cisco IOS Image -- To run these features on T1/E1 interfaces, you must install an IP Plus or IP Voice image (minimum) of Cisco IOS Release 12.3(14)T or a later release.
http://www.cisco.com/en/US/products/ps5853/products_data_sheet0900aecd8016a59b.html
Sundar
11-03-2006 08:11 PM
Before attempting to upgrade the IOS, can you try adding this command in the global config mode:
card type {t1 | e1} slot [bay]
Command info here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tvr/vrht_c4.htm#wp1060457
Sundar
12-05-2006 08:57 AM
Thanks Sundar, I could solve my problem. I just needed to apply the command.
Thank you very much
Best regards!
