01-22-2021 07:16 PM
VWIC3-2MFT-T1/E1
I have one card on cisco 1921 and i need to configure this to interface with SDH using E1 and the other side i have one Router connected in Datacom modem.
Router Cisco 1921 (VWIC3-2MFT-T1/E1) ===> SDH Hauwei <===========> SDH Hauwei =====> Modem Datacom ==> Cisco 2911 (HWIC-2T)
Router Cisco 1921
c1900-universalk9-mz.SPA.154-3.M3.bin
VWIC3-2MFT-T1/E1
anyone can help with cli command ?
This type of topology works ?
I tryed to configuring unframe E1 but it does not accepted the commands.
ex:
Router(config-controller)#channel-group 0 unframed
% Invalid input detected at '^' marker.
01-22-2021 10:38 PM
- Check if this thread can help :
M.
01-25-2021 02:45 PM
Marce1000,
In my case i have two type of interface (VWIC3-2MFT-T1/E1 and HWIC-2T) in each site and i would like establish communication beetwen them with HDLC protocol.
I think that i need do a unchannalized configuration on module VWIC3-2MFT-T1/E1 with command: "channel-group 0 unframed" , but it is not working.
Does anyone have any ideia how it works ?
How can i do this kind of the configuration ?
01-26-2021 12:32 AM
Hello @santos_ligeiro ,
if you have SDH ADM in the middle you can use a framed E1
controller e1 0/0
channel-group 1 1-15,17-31
timeslot 16 is the control channel D and timeslot 32 is used for framing.
Hope to help
Giuseppe
01-26-2021 07:53 AM
Hello Giuseppe Larosa
In my case I do not have access to SDH , however i will speak to responsible person about this kind of configuration on SDH.
BUT Is there another way to solve this problem just by configuring the Cisco Rotuers?
