Wan access
niiodaie76
Hello Im trying to route traffic from my cisco 3550 router to the internet through my ISP provided router.
i have configure DHCP on the 3550 router interface going to the ISP router- and can see it receiving and IP from an IP on the configuration page. I am howver not able to ping any host on the network from the router and unable to route to the internet. i have pasted my configuration here for any inputs
Router#
Router#show run
Building configuration...
Current configuration : 1702 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.1.1 172.16.1.32
ip dhcp pool insideDCHP
ip dhcp pool insideDHCP
   network 172.16.0.0 255.255.0.0
   default-router 172.16.1.1
   dns-server 68.94.156.1 68.94.157.1
ip cef
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
interface FastEthernet0/0
description Facing ISP (WAN)
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1
description Facing LAN
ip address 172.16.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source route-map NAT_ISP interface FastEthernet0/1 overload
access-list 1 permit 172.16.1.0 0.0.0.255
access-list 2 permit any
route-map NAT_ISP permit 10
match ip address 1
match interface FastEthernet0/0
control-plane
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
3 Accepted Solutions
Hello
you need to enable ip routing and provide and provide a default route
Conf t
Ip routing
Ip route 0.0.0.0 0.0.0.0 (wan ip next hop)
What do you have attached to the fa0/0 LAN interface.
Do your clients receive a dhcp release.
Res
paul
Kind Regards
Paul
Renan Abreu
Why do you have two NATs configured? what are you trying to achieve there?
Routing is a good point to tshoot either.
no ip nat inside source list 1 interface FastEthernet0/0 overload
no ip nat inside source route-map NAT_ISP interface FastEthernet0/1 overload
ip nat inside source list INTERNET-ACCESS interface FastEthernet0/0 overload
ip access-list extended INTERNET-ACCESS
permit ip 172.16.1.0 0.0.0.255 any
no ip dhcp pool insideDHCP
   network 172.16.1.0 255.255.255.0
ip routing
interface fa 0/0
no shut
interface fa 0/1
no shut
*** Do Rate All Helpful Posts***
Jawad
5 Replies 5
Hello
Conf t
Ip routing
Res
paul
Kind Regards
Paul
I have an AT&T router attached to fa0/0 and 3550 switch to Fa0/1.
thanks
Renan Abreu
ip routing
interface fa 0/0
no shut
interface fa 0/1
no shut
Jawad
Very helpful
made the neccessary changes and got it working.
