WAN and serial ports (cables)
Translator
Community Manager
Community Manager
To configure WAN, you use serial port (cable) to connect among routers.
Why do we use only serial port? Can't we connect by Ethernet?
Richard Burts
I do not know the context of this question. But I believe that it reflects a very old view of router configuration. Many years ago most Wide Area Network connections were based on serial interfaces. The serial connections were effective over longer distances, while Ethernet was limited about the distances it could operate on. In modern times the technology has changed, especially in terms of Ethernet for long distances. So it is common in modern network configuration to use Ethernet for WAN.
Rick
여보세요,
이전에는 이더넷 포트를 사용하여 두 라우터를 서로 연결하기 위해 크로스오버 케이블(핀 1과 3, 핀 2와 6이 뒤바뀜)이 필요했습니다. 대부분의 최신 라우터에는 인터페이스가 연결된 케이블을 감지할 수 있는 MDIX 기능이 있으므로 직선 이더넷 케이블을 사용할 수도 있습니다.
https://www.youtube.com/watch?v=rgUDN4YBJhk
