WAN Assistance
melwin.uk
Hi Experts!
How do I get this working
Location_A needs to be connected to Location_B over E1.
Location_A terminate P1 / P2 / P3 / P4
Location_B will soon terminate P11 / P12 / P13
Location_A should have reachability to P11 / P12 / P13
Location_B should have reachability to  P1 / P2 / P3 / P4
P1 / P2 .....etc are sales offices
Location_A  got 4506
Location_B  got 4506
ISP and Location_A are sharing the same floor and need to extend internet on the same E1 connection to Location_B
ISP UTP cable terminated on 2960 switch.
ISP Bandwidth 20MB
Location_A needs 15MB Bandwidth
Location_B needs 5MB Bandwidth
Tharak Abraham
Level 3
Level 3
What is blocking you from this requirement ?
Are you talking VPNs or leased lines or ?
Are you expecting the entire Design plan to be made for you ?
(which i believe ppl wont do it for free)
Start implementing, if you are stuck up ..come back we'll help..-:)
Hello
I am looking for suggestions. I plan to terminate the E1 on 4500 as L3 connection another option is GRE Tunnel.
Can I get suggestion Experts
