WAN connectivity
my quest is what is the technical differnece b/w Serial and Ethernet interface interms of WAN connectivity as we are plannig to move from stm1 serial connection over to gigabit ethernet interface
paolo bevilacqua
There are many differences, so that it can't be summarized in this small space.
You can read about on the internet, or just rely on your lead engineer (if you have one),
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
How technical?  Each has different bandwidth overheads.
From a practical standpoint, if you're obtaining a GigEtherent handoff with (say) 150 Mbps of contracted bandwidth vs. your STM1's 155 Mbps, you probably want to shape for the contracted rate.  Generally, it would be difficult to see much of an effective bandwidth difference if the GigEthernet is rate-limited to such a similar value as the STM1.  However, often the contracted bandwidth, on the GigEthernet, can be easily and quickly changed.
One subtle difference, equipment that supports STM interfaces is more likely to offer extensive QoS features than equipment that supports Ethernet interfaces which can be especially important for WANs.
