WAN failover - Teleco Cloud issues
Steve Coady
Hello
I have (15) sites around the country
Each site has a Telco WAN link
Eachs site has a secondary link over Cable.
The (2) links have an VRRP config between them to facilitate failover.
The WAN router monitors the WAN interface and if it goes down, then the VRRP initiates the failover to the Cable link.
Once the Telco WAN link comes back, it resumes as priority.
(CER router)
interface Multilink1
description connection to TELCO Circuit
bandwidth 3072
ip address 172.16.a.y 255.255.255.252
ppp chap hostname (name)
ppp multilink
ppp multilink group 1
no cdp enable
service-policy output COS_Profile
interface GigabitEthernet0/0 - This interface connects to my HE switch. The Cable link is also connected to my HE switch.
description connection to customer LAN
ip address 192.168.a.101 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow ingress
duplex full
speed 100
vrrp 1 ip 192.168.a.1
vrrp 1 priority 105
vrrp 1 track 202
ip sla 2
icmp-echo 172.16.a.z (PER router) source-interface Multilink1
frequency 10
ip sla schedule 2 life forever start-time now
See attached for topology.
PROBLEM:
When the WAN link drops due to a problem farther into the Telco cloud, the VRRP failover never initiates the failover.
QUESTION
     What other options are there in the WAN router to config to monitor other than the interface to detect a WAN outage?
          Can BGP updates be monitored
sMc
mfurnival
Level 4
Level 4
This document gives the available options for VRRP tracking:
http://www.cisco.com/en/US/docs/ios-xml/ios/ipapp_fhrp/configuration/12-4/fhp-vrrp.html#GUID-2711A06C-2B31-4C7A-B895-28F1A532C106
Tracking the remote end of your WAN link is not ideal as it won't detect a BGP issue or problems further in the cloud. Try tracking a route received from your primary provider with the "track ip route" command.
5 Replies 5
mfurnival
Level 4
Level 4
mfurnival
Thankyou for the reply. I will followup with that.
sMc
John Blakley
Steve,
In this scenario, it's going to be difficult to determine when to roll over if the PE is up. I'm not sure how you're set up, but what would you like to monitor past the PE, that would be reliable enough, and you'd be willing to fail over if it were to go down? I'm assuming that your Netgate is still tied to your mpls cloud as well?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John
The Netgate passes traffic across the Cable connection to an AVPN VIG which put the traffic back on my AVPN link.
sMc
My thought is:
If the PE-CE link is compromised other than a direct down link, then the routing updates should timeout or be affected somehow.
Can i monitor routing protocol table times/timeouts and use that to initiate the VRRP faoilover?
sMc
