WAN / LAN port Cisco
salmaan.ozeer
Can anybody please tell me the real limitations of a WAN FE port v/s a LAN FE port ?
For example I have a C887VA-K9 router where I have 1 "VDSL2/ADSL2/2+" WAN port and 4 FE LAN ports. I was previously using the WAN port for ADSL, but now we are migrating to Ethernet.
Can I use anyone of the FE LAN ports as WAN port ? What are the real limitations ? I haven't come across any detailed document on the subject.
Thanks.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
On the small 800 series, it's not so much the limitations of the WAN FE vs. the LAN FE, but the limitations of a LAN FE vs. the WAN FE.
The WAN FE pretty much behaves much like a routed port on the ISRs, while the LAN FE ports behave like L2 switch ports (which can often be added to ISRs).
Yes, you can often use a LAN FE port as your WAN port, but you'll find it has configuration limitations compared to the WAN FE port.  For example, often you cannot configure an IP address directly on any LAN FE port.
Joseph W. Doherty
Disclaimer
Posting
