WAN link on 800 series router switch port
mayank.parekh
Can we terminate 2 WAN link first Lease line and second Broadband internet link on 800 series router .
As 800 series router have only 1 wan port and 4 switch port.  Also we want to Configure load balancing over the 2 WAN link please suggest is it possible or Basic router for SMB.
Thnaks & Regards
Calin C.
Level 5
Level 5
From what you described, you cannot terminate 2 WAN connection on one WAN port...Load balancing we don't even discuss with this equipment.
You can however investe something like 300$ in a Cisco RV042, which is dual WAN (
http://www.amazon.com/Cisco-RV042-4-port-100-Router/dp/B0002I7288) or if you have something more to spend, you may go for 1800 series.
HTH,
Calin
