WAN load balancing in cisco router 1941
indsys
Hai
i have cisco 1941 router with HWIC-4EWS Card
We have two ISP,
pls guid me , how to configure the load balancing
paolo bevilacqua
pls check this....
Router#show run
Router#show running-config
Building configuration...
Current configuration : 4441 bytes
! Last configuration change at 09:47:37 UTC Thu Nov 29 2012 by indsys
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip name-server 218.248.241.4
ip name-server 218.248.241.6
ip name-server 4.2.2.2
ip name-server 202.138.103.100
ip name-server 202.138.96.2
crypto pki trustpoint TP-self-signed-3402979621
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3402979621
revocation-check none
rsakeypair TP-self-signed-3402979621
crypto pki certificate chain TP-self-signed-3402979621
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  7C2B492B 5054163B 7DE70A33 F19C97
        quit
license udi pid CISCO1941/K9 sn FGL1635148F
username indsys privilege 15 secret 4 ZciXE.iy7zVRjPuXmv2cyfVC/6N.gMVf1/0n4L0eoq
c
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description "BSNL WAN LINK - 10 Mbps"
ip address 117.239.245.X 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description "RELIANCE"
ip address 220.225.200.45 255.255.255.252
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/0
switchport access vlan 100
no ip address
interface FastEthernet0/0/1
description "LAM"
switchport access vlan 500
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
interface Vlan500
ip address 192.168.22.1 255.255.255.0 secondary
ip address 192.168.23.1 255.255.255.0 secondary
ip address 192.168.24.1 255.255.255.0 secondary
ip address 192.168.25.1 255.255.255.0 secondary
ip address 220.225.200.X 255.255.255.248 secondary
ip address 192.168.18.1 255.255.255.0 secondary
ip address 192.168.19.1 255.255.255.0 secondary
ip address 192.168.20.1 255.255.255.0 secondary
ip address 192.168.21.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool REL 220.225.200.x 220.225.200.x netmask 255.255.255.248
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 220.225.200.46
access-list 100 permit ip 192.168.20.0 0.0.0.255 any
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 101 permit ip 192.168.21.0 0.0.0.255 any
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
control-plane
banner motd ^CELCOM TO VSB ENGINEERING COLLEGE
^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
password
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Don't get offended, but if your intention is to do Cisco yourself without hiring an engineer, first you should try yourself, and only after possibly ask for further help and check configuration that you made.
