WAN optimization
minimintu
how to optimize the transport for internet and intranet traffic?...one answer can be with wan accecelarator..but what are the other options?..what are the products required and their specification...can somebody help me out...
5 Replies 5
guruprasadr
Level 7
Level 7
Yes, you can do with WAN Optimizer.
Product Required: River Bed
Pls see the Link for Details: http://www.riverbed.com/products/
Pls Rate if Helps ! !
Best Regards,
Guru Prasad R
is there any other product apart from riverbed?...
There are several products out there in the market similar to RiverBed, which address the WAN acceleration needs.
Cisco has WAAS suite of products to address this. It also has AVS suite of products targeted only for web accelerateion, which will accelerate http/https traffic.
There are also other niche players emerging in this market competing in this area.
You may have to study your requirements in detail before proceeding with testing any of these products available in the market.
As this segment is new to the industry, you have to carefully draft your needs and look out for a solution. Clearly till date, there is no one point product available in the market which can address all these needs.
Hope this helps.
-VJ
You can look at the following options
Riverbed, www.riverbed.com
Packeteer, www.packeteer.com
Cisco WAAS, www.cisco.com/cdc_content_elements/flash/waas
Bluecoat, www.bluecoat.com
HTH, rate if it does
Narayan
Narayan, your post helps
