WAN port Capability of ISR
mohnegi
Recently I had a meeting with a tier 2 ISP. He had two requirements
1)  Router with 2 gbps for WAN ports and 4 1gbps LAN ports.
2) Router with 10 gbps for WAN and 10gbps for LAN.
On going through datasheets I found that ISR4k can deliver 2gig and ASP 1001x can deliver 10 gig, but both of these routers are turning out to be an expensive solution. Competition(huawei) is providing at must lower cost
on 800 series routers, we have 2 gig WAN ports, but on datasheets it is written for upto 15 mbps only.....why is it so as we have WAn gig ports on these series WAN
Please help with a solution..Thanks in advance.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Likely because it provides flexibility to what you can connect to.  And/or, it might also streamline the manufacturing process, i.e. just use a same gig NIC hardware in multiple platforms.
