wan problem plz help
cwynne001
i have vlan separated by a switch my pc's can communicate on their own lans but not across the wan can anyone help me please
router 1
Router#show run
Building configuration...
Current configuration : 1004 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
spanning-tree mode pvst
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
interface FastEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial0/0/0
 ip address 10.0.0.2 255.255.255.252
 encapsulation ppp
 ppp authentication chap
 clock rate 64000
interface Serial0/0/1
 no ip address
 clock rate 2000000
interface Vlan1
 no ip address
 shutdown
router ospf 1
 log-adjacency-changes
 network 192.168.2.0 0.0.0.255 area 0
 network 192.168.1.0 0.0.0.255 area 0
 network 10.0.0.0 0.0.0.3 area 0
router rip
 version 2
ip classless
line con 0
line vty 0 4
 login
end
router 2
Router#show run
Current configuration : 1000 bytes
version 12.4
hostname Router
 no ip address
 duplex auto
 speed auto
 ip address 192.168.1.104 255.255.255.0
 ip address 192.168.2.104 255.255.255.0
 no ip address
 duplex auto
 speed auto
 shutdown
 ip address 10.0.0.1 255.255.255.252
 encapsulation ppp
 no ip address
 clock rate 2000000
 shutdown
interface Vlan1
 no ip address
 shutdown
router ospf 1
router rip
 version 2
ip classless
line con 0
line vty 0 4
 login
end
Jon Marshall
Sarbjit-2014
This will never work you have the same LAN subnets on both routers 192.168. Unless you use NAT on one of the routers.
