cisco 877w -Configuration of subinterfaces and main interface within the same bridge group is not permitted
marekpro607
I have another problem - after upgrade ios wirelles connection not work.
After reload i have :
STP: Unable to get the port parameters.
Please configure the bridge group on this interface first.
SETUP: new interface NVI0 placed in "shutdown" state
my old configuration work propertly in the old software, but after update i have notificatio.
Old thread:
https://supportforums.cisco.com/discussion/12379491/cisco-877w-no-wireless-connection
my current sh run:
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname cisco
boot-start-marker
boot system flash:c870-advipservicesk9-mz.124-24.T6.bin
boot-end-marker
logging message-counter syslog
logging buffered 4096 informational
enable secret 5 $1$eCNp$rWuBfZ/cexnwnkm7L447s.
aaa new-model
aaa session-id common
dot11 syslog
dot11 ssid ciscowifi
 vlan 1
 authentication open
 authentication key-management wpa
 guest-mode
 wpa-psk ascii 7 050D031D26595D0617
dot11 wpa handshake timeout 500
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.56.1
ip dhcp pool CLIENT
   import all
   network 192.168.56.0 255.255.255.0
   default-router 192.168.56.1
   dns-server 8.8.8.8 194.204.159.1 194.204.152.34
   lease 0 2
ip cef
no ip domain lookup
no ipv6 cef
username marek password 7 00121A0908500A
archive
 log config
  hidekeys
ip tcp path-mtu-discovery
bridge irb
interface ATM0
 description Polaczenie ADSL do ISP$ES_WAN$
 no ip address
 no atm ilmi-keepalive
 pvc 0/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
 hold-queue 224 in
interface FastEthernet0
 description Edzia
interface FastEthernet1
 description dom
interface FastEthernet2
 description Dziadek
interface FastEthernet3
interface Dot11Radio0
 no ip address
 no ip redirects
 ip local-proxy-arp
 ip nat inside
 ip virtual-reassembly
 no dot11 extension aironet
 encryption vlan 1 mode ciphers tkip
 encryption mode ciphers aes-ccm tkip
 broadcast-key change 3600
 ssid ciscowifi
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 world-mode dot11d country AU indoor
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0.1
 description ciscowifi
 encapsulation dot1Q 1 native
 no cdp enable
interface Vlan1
 no ip address
 bridge-group 1
interface Dialer0
 description Interfejs dzwoniacy
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp chap hostname cos@neostrada.pl
 ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxx
interface BVI1
 description Polaczenie dla sieci LAN
 ip address 192.168.56.1 255.255.255.0
 ip nat inside
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
ip nat inside source static tcp 192.168.56.10 80 interface Dialer0 80
ip nat inside source static tcp 192.168.56.10 22 interface Dialer0 22
logging trap debugging
logging 192.168.56.10
access-list 100 permit ip 192.168.56.0 0.0.0.255 any
access-list 100 deny   ip any any
no cdp run
snmp-server community ciskacz RO
snmp-server chassis-id ciskacz
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 0 0
 transport preferred ssh
 transport input ssh
scheduler max-task-time 5000
end
please help - thanks!
Peter Paluch
Hello Marek,
I suppose you are not planning to do any kinds of advanced config using several VLANs and multiple SSIDs so let's just make your configuration simple and working.
In short, you need to remove all references to VLAN 1 and to any subinterfaces possibly related to the VLAN 1. This means in particular (follow these steps in sequence):
  • Remove the Dot11Radio0.1 subinterface entirely
  • In the Dot11Radio0 section, remove the encryption vlan 1 mode ciphers tkip command
  • In the dot11 ssid ciscowifi section, remove the vlan 1 command
  • After performing these steps, make sure that the ssid ciscowifi and encryption mode commands are still present in the Dot11Radio0 configuration, and if not, reenter them.
Best regards,
Peter
