WAN QoS and DSCP from LAN not recognised
sganpat
I'm implementing QoS and encountered a problem where the router is not recognizing the DSCP information from the LAN.
On the LAN Switch port connected to the router I have:
interface GigabitEthernet0/1
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
queue-set 2
mls qos trust dscp
auto qos voip trust
On the Router I have:
class-map match-any VOICE_BEARER_TRAFFIC
match ip dscp ef
class-map match-any VOICE_CONTROL_TRAFFIC
match ip dscp cs3  af31  cs5
policy-map WAN_OUT_CHILD
class VOICE_BEARER_TRAFFIC
    priority percent 10
class VOICE_CONTROL_TRAFFIC
    bandwidth percent 2
class class-default
    fair-queue
     random-detect
policy-map WAN_OUT_PARENT
class class-default
    shape average 1000000
  service-policy WAN_OUT_CHILD
interface GigabitEthernet0/0
bandwidth 1000
service-policy output WAN_OUT_TSTT_SANDO
However, when I do a "show policy int gig0/0" I get:
RTR#sh policy-map interface GigabitEthernet0/0
GigabitEthernet0/0
  Service-policy output: WAN_OUT_PARENT
    Class-map: class-default (match-any)
      343734 packets, 65366192 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 343721/65278879
      shape (average) cir 1000000, bc 4000, be 4000
      target shape rate 1000000
      Service-policy : WAN_OUT_CHILD
        queue stats for all priority classes:
          (pkts output/bytes output) 0/0
        Class-map: VOICE_BEARER_TRAFFIC (match-any)
          0 packets, 0 bytes
          Match: ip dscp ef (46)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Priority: 15% (150 kbps), burst bytes 3750, b/w exceed drops: 0
        Class-map: VOICE_CONTROL_TRAFFIC (match-any)
          0 packets, 0 bytes
          Match: ip dscp cs3 (24) af31 (26) cs5 (40)
            0 packets, 0 bytes
            5 minute rate 0 bps
          Queueing
          bandwidth 3% (30 kbps)
          239067 packets, 49815430 bytes
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
          (pkts output/bytes output) 239080/49822124
          Fair-queue: per-flow queue limit 16
            Exp-weight-constant: 9 (1/512)
            Mean queue depth: 0 packets
            class     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                      pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
            0          239080/49822124        0/0              0/0                 20            40  1/10
            1               0/0               0/0              0/0                 22            40  1/10
            2               0/0               0/0              0/0                 24            40  1/10
            3               0/0               0/0              0/0                 26            40  1/10
            4               0/0               0/0              0/0                 28            40  1/10
            5               0/0               0/0              0/0                 30            40  1/10
            6               0/0               0/0              0/0                 32            40  1/10
            7               0/0               0/0              0/0                 34            40  1/10
All the traffic is shown in the default class, and nothing is being matched in the traffic classes configured.
If I look at the switch QoS statistics on the port that connected to the router I see classed traffic leaving and entering the switch port.
SW#sh mls qos interface gig0/1 statistics
GigabitEthernet0/1
  dscp: incoming
  0 -  4 :   890120760            0          115            0          106
  5 -  9 :           0          120            0         7364            0
10 - 14 :        5185            0         4264            0           26
15 - 19 :           0          250            0         1583            0
20 - 24 :           0            0         3803            0           16
25 - 29 :           0         2640            0         3540            0
30 - 34 :           0            0        56928            0      3875576
35 - 39 :           0            4            0         3429            0
40 - 44 :    26086277           42            0            0            0
45 - 49 :           0    195433083            0     13143148            0
50 - 54 :           0            0            0            0         1353
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            3
  dscp: outgoing
  0 -  4 :   868314905            0            0            0          286
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            1            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0        56916            0      4326017
35 - 39 :           0            0            0            0            0
40 - 44 :    12339636            0            0            0            0
45 - 49 :           0    192006693            0     87391218            0
50 - 54 :           0            0            0            0          358
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :  1143645037            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :   934164530            0            1            0            0
  5 -  7 :      213672    254270653         7478
What is going on? Why is traffic not being classed or recognised by the router?
Sachin
abarakat77
no L3 node before the router  on the path ? you need to trust also his port
All link inter switch need to be trusted also, you need to trust any port who will inject the dscp traffic on your lan
you can made a packet capture on the router to verify the incoming traffic
http://www.cisco.com/en/US/products/ps10591/products_configuration_example09186a0080bf0163.shtml
Nothing between the switch and the router. I will do a packet capture to determine if any DSCP headers are being sent.
Thanks for the reply.
sganpat
Sorry that I didn't update this. The problem was the Nortel phone weren't using COS, so I had to set it to trust DSCP on the phone interfaces as well (not just on the interfaces to the router). It was a simple configuration error.
Sachin
