WAN QoS (Cisco 831, DSL Internet)
panweicisco
Hi everybody,
I have a Cisco 831 router connected to internet via DSL modem. The IOS is 12.4, the upstream bandwidth is about 800kbps. I have the following QoS needs (priorities descend).
1. Limit the upstream bandwidth to 750kbps, drop any packets exceeding 750kbps.
2. This class is "voip_traffic". Within the 750kbps, I want to guarantee 150kbps to three VoIP devices (their IPs are 192.168.1.95, 192.168.1.96, 192.168.1.97). They need the least delay.
3. This class is "premium_traffic", will provide bandwidth with low delay to some light protocols, like: DNS, ICMP.
4. This class is "express_traffic", will provide bandwidth for services like web browsing. I don't want users to wait for too long when the circuit is busy, but reasonable waiting time is acceptable.
5. This class is "standard_traffic", for services like FTP. No so time-sensitive.
6. This class is "bulk_traffic". No bandwidth is guaranteed. For services like P2P uploading.
I have attached my running-config. Please suggest how to configure the QoS, and which interface I should apply the policy.
Your help is greatly appreciated!
jheckart
Level 3
Level 3
I put together a sample qos config that you'll want to edit. I would recommend maybe using percentages instead of kbps. Also, if you do use percentages, you'll want to set the bandwidth on the interface to either 750 or 800.
The shaping will keep the traffic exiting at 750kbps. Also, the policy-map six-class is nested in the shaping, so the shaping happens first, then the qos.
Good luck, and post back with questions.
ip access-list extended phones
permit ip host 192.168.1.95 any
permit ip host 192.168.1.96 any
permit ip host 192.168.1.97 any
deny ip any any
class-map match-any voip_traffic
match ip dscp ef
match ip access-group name phones
class-map match-any premium_traffic
match protocol icmp
match protocol dns
class-map match-any express_traffic
match protocol http
match protocol https
class-map match-any standard_traffic
match protocol ftp
class-map match-any bulk_traffic
match protocol bittorrent
match protocol kazaa2
class voip_traffic
priority 150
class premium_traffic
bandwidth 200
class express_traffic
bandwidth 150
class standard_traffic
bandwidth 100
class bulk_traffic
bandwidth 1
class class-default
fair-queue
policy-map shape_six-class
class class-default
shape average 750000
service-policy six-class
interface dialer0
service-policy output shape_six-class
One other thing... for the protocol matching, you have to have nbar turned on. For the class-map's, I did match-any, which means that traffic will be classified if it meets any of the matches in the class. On the phones ACL, if your phones are marking EF, you won't even need the ACL, but either the ACL or EF would match.
Jeff
