WAN QoS Questions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-12-2012 11:14 AM - edited 03-04-2019 02:53 PM
We are planing to implement the WAN QoS polic to apply on the routers for sites. They all are connected to our service provider via MPLS. We will make policy for voice, video and data. We have Cisco VoIP phones and some other equipments for voice, and have Polycom for video conferencing. There are 5 classes, one class will be configured for voice traffic and one class will be configured for video conferencing. For video conferencing, we are using ACL. We don't want the voice traffic from video conferencing falling into the voice class. My question is how to distinguish between voice traffic for VoIP phone, Polycom' video and voice for video traffic. Another question is it will be covered all voice traffic when using "match protocol RTP" Please advise.
Here is part of the qos config.
class-map match-any voice-traffic
match protocolRTP
class-map match-any video-traffic
match access-group 100
policy-map QOS
class voice-traffic
bandwidth percent 10
set ip dscp ef
class video-traffic
bandwidth percent 30
set ip decp af41
access-list 100 permit ip host 10.10.254.1 any
access-list 100 permit ip any host 10.10.254.1
access-list 100 permit ip host 10.10.253.1 any
access-list 100 permit ip any host 10.10.253.1
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-12-2012 12:01 PM
First of all you usually have a policy map to mark on the inbound LAN interface and then a policy on the outbound to set your percentages.
so lets say
Class-map match-any MARK_EF
Match access-group name MARK_EF
Class-map match-any MARK_AF41
Match access-group name MARK_AF41
Class-map match-any MARK_AF31
Match access-group name MARK_AF31
policy-map MARK_IN
class MARK_EF
set ip dscp ef
class MARK_AF41
set ip dscp af41
class MARK_AF31
set ip dscp af31
class class-default
set ip dscp default
ip access-list extended MARK_AF41 (Sample acl, this matches any dscp41,42,43,cs3 and telnet and resets to af41)
permit ip any any dscp af41
permit ip any any dscp af42
permit ip any any dscp af43
permit ip any any dscp cs3
remark TELNET
permit tcp any any eq telnet
permit tcp any eq telnet any
Then something like this outbound, wred is optional.
class-map match-any COS-EF
match dscp ef
class-map match-any COS-AF41
match dscp af41
class-map match-any COS-AF31
match dscp af31
policy-map COS_OUT
class COS-EF
priority 256
class COS-AF41
bandwidth remaining percent 40
random-detect dscp-based
class COS-AF31
bandwidth remaining percent 39
class class-default
bandwidth remaining percent 21
I believe in the polycom set up you can set your dscp for the voice and video to whatever you want, so if you set it to 41, then you could match on that or you could match on source ip address etc, just put it in acl. I'm also not sure if you need to match on protocol rtp as most phones set dscp to ef so just match on dscp EF. Which actually brings me to a question I have, is there any benefit to setting 2 classes with almost the same bandwidth? I'm about to post that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-12-2012 02:46 PM
Hey Joe,
Not to offend you but I wont keep posting the same stuff all night.
Seems like today is World QOS day, never before had so many questions about this topic in such a short timespan.
Please look here, I believe it also answers your questions:
https://supportforums.cisco.com/thread/2125467?tstart=0
regards,
Leo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-12-2012 03:22 PM
about the media streams from the video endpoints
there should be an option to mark video and audio generated from the endpoint and then in the network you can treat as you want to
Cisco best practice is to mark the video and audio streams generated from VC endpoints same marking ( video marking ) AF41 this way it will not overlap with telephony VOIP marking
not sure if polycom has the option to mark the audi and video but Cisoc products they do have it
also make sure that your marking is being aligned with the MPLS service provider COS marking if you have purchased some qos classes from them
hope this help
if helpful Rate
