WAN Routing between N5K (L3-vPC) & VSS (MEC) with Link Aggregation
AdnanShahid
Hi All,
We want a solution for routing between N5K and VSS with aggregated WAN links. Here is the scenario.
DC1: It has 2 cisco 6509 with VSS. There are 4 server farm cisco4948 switches connected with VSS with redundant uplink via MEC. Server gateway is the VSS. VSS is running Eigrp routing.
DC2: This is a new datacenter we are going to establish soon. We are planning 2 N5K at core layer with L3 daughter card and 4 N2K as server farm switch. 2 N5K will have vPC peer between them. Each 4 N2K will connect with redundant uplink via vPC with this N5K. N5K will run Eigrp routing and will be the gateway of this new DC server.
WAN between DC1 & DC2: DC1 VSS will connect with DC 2XN5K with 2X10G links. we want to do MEC at VSS side and L3 vPC at DC2 side.
If we have VSS at both end it might not be a problem. Both the link will work together as 20G aggregated link. But as we are using N5K at one end, so it creates a confusion whether it will work properly is this scenerio or not. This is my 1st question.
Also I would like to know,
1) In VSS I have configured 1 VLAN interface for server gateway. But in N5K do I have to configure at 2 switch seperately?
2) In WAN routing VSS shows as 1 device. Does this 2 N5K will show as 2 seperate hops or L3 vPC will allow them to act as a single device while traceroute from one end to another end.
I am not sure if my questiones are so elementary level or not. As I am very new to this technology I would like you all to get me some suggestions or documention or links regarding this design. I am also attaching the diagram.
BR//
Adnan
2 Accepted Solutions
You solution in step 1-3 are fine. I will use the same solution based on the following:
1. VSS is a logical switch, in the N5K's perspective, it is 1 switch. You are acutally ECMP upstream, which is good. Just let routing protocol to take care the job.
2. The cross /30 link between N5K-1 and N5K-2 is used only if one uplink failed. Please note that the L3 /30 cross link is not part of vPC peer-link. It is a dedicated interface. Please see the below diagram.
In term of HSRP, you have to understand one thing first. In vPC, HSRP behavior has modified, both switch will forward traffic (different from C6K where only one is active). Please see the below link on how HSRP works under vPC (somehow this link is broken right now, let me see if I can get someone to fix it):
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/white_paper_c11-516396.html
To answer your question:
1. When N5K-1 goes down, N5K-2 will forward traffic out, and vise versa.
2. When vPC peer-link goes down. vPC secondary will shut down all vPC related interfaces and SVI. If SVI is down, routing protocol will stop the advertisement.
HTH,
jerry
You VLAN 77 in the N5K is not configured to be advertised into EIGRP. Add the following commands in both N5K and it should work:
interface vlan 77
  ip router eigrp Test1
  ip passive-interface eigrp Test1
HTH,
jerry
19 Replies 19
Jerry Ye
L3 (routing protocol) over vPC is not supported. You are better off to use L3 ECMP.
HTH,
jerry
Hi Jerry,
Thanks for your reply. I was actually surfing through this forum to find out any solution related to my problem. Please see that below link. I guess the problem is almost similar to my query and I have seen your reply to that solution too.
https://supportforums.cisco.com/thread/2105463
As per the understanding what I have found that,
1) Between DC1 (VSS) to DC2 (2XN5K) we will implement 2 10G link as per our requirement in the following way.
  • 1st link: DC1 VSS to DC2 N5K SW1
  • 2nd Link: DC1 VSS to DC2 N5K SW2
2) Both this link will have /30 subnet and would be included in EIGRP routing by following way,
  • 1st link: /30 will be included in DC1 VSS & DC2 N5K SW1 EIGRP ROUTING.
  • 2nd link: /30 will be included in DC1 VSS & DC2 N5K SW2 EIGRP ROUTING.
3) There will be another 1 link with /30 subnet between DC2 N5K SW1 and SW2. This subnet will be included in both the ROUTING of DC2 N5K SW1 and SW2.
Now the most challanging part is the DC2 Server IP Subnet HSRP and How to maintain the redundancy. As of my understanding I have to create SVI at N5K SW1 with main GW (x.x.x.254) and another SVI at N5K SW2 with standby GW (x.x.x.253). Now my question is how the redundancy will occure,
  1. When DC2 N5K switch goes down,
  2. When Peer link between N5K goes down.
I am sorry if these question sounds very amature. Actually we are very new the Nexus and hence needs to clarify and go in details as much as possible before choosing this product family.
Waiting for your expert opinion.
BR//
Adnan
HTH,
jerry
Hi Jerry,
Few days back we have got the N5K and N2K product. Currently we have deplyed these as a test bed to test the configuration before proceed for the final deployment on 1st week of next month.
So far we have configured VPC Keepalive (2x10G) & VPN Peer (1x1G) between N5K. Also we have configured one N2K with Dual Hommed VPC with both N5K.
Now I am having some difficulties with desining/configuring EIGRP with Upstream routers/L3 65xxVSS switch.
Here is the queries,
1) I have to create another 1GE link between these 2 N5K.
2) For these 2xN5K I have to define Eigrp on physical Interface or Have to create VLAN & VRF to enable routing in between.
3) For N5K to Upstream L3 device I have to configure Eigrp (Either on phy int or create VLAN, VRF).
Appreciate if you can suggest me or share me any doc/link configuring Eigrp between N5K with other L3 device.
Thanks a lot.
Adnan
I am assuming you mean 2x10G for vPC peer-link and 2x1GE for vPC peer-keepalive (I think you have that reversed in your description).
1) Yes, you "should" have a point-to-point L3 link for EIGRP between the N5Ks as per my diagram before.
2) I think you mean routing over the newly P2P L3 link? Routing should be done on physical.
3) Routing on interfaces to upstream should be done on physical link also.
In another word, try not to use SVI on L3 P2P interfaces, it is not necessary. If your L2 domain is not properly set up, and when you use SVI to enable routing, it might cause problem in vPC.
jerry
Hi Jerry,
Thanks a lot for your answers. As per your previous discussion here is what I understood,
1) "try not to use SVI on L3 P2P interfaces, it is not necessary." - this is a helpful suggestion for me. I have searched internet and find out that in some documents they use SVI and in other documents they - which makes me a little confuse. As you said, so I will avoid this and do EIGRP on physical interface.
2) We are using only one 1GE link for VPC keepalive and 2x10GE link for VPC peer. Yes you are right.
3) For L3 routing between these 2 N5K I will create another L3 Link and configure EIGRP on both N5K on the physical interface with /30 subnet.
4) We have 2 DC with 2 link each. DC1 with 1GE, 1GE and DC2 has 1GE, 10GE. These 2 links from each DC will connect with /30 subnet to each of N5K switchs.
     N5K-1 >> DC1-1GE and DC2-10GE
     N5K-2 >> DC1-1GE and DC2-1GE.
     For all these 4 links I will configure EIGRP in interface at N5K end and configure EIGRP in "router eigrp" at other end.
5) Also need to know how I should proceed with Summary route. Does EIGRP will automatically summarize the subnets. Any suggestions.
Please confirm me if the Point 3, Point 4 and Point 5 will provid me the complete and proper Routing between all the DC.
Waiting for your feedback. Thanks a lot.
Adnan
Below are the answers:
3) yes.
4) What do you mean DC2 wil have 1x 10GE link? Yes, you should configured that on the physical interface.
5) EIGRP will not summarize addresses automatically. Nexus has "no auto-summary" on by default. If you want to summarize addresses, you need to configure them specifically on the interface with "ip eigrp summary" command.
HTH,
jerry
Hi Jerry,
Thanks a lot for your suggestions. Please find my comments.
4) For DC2 we have 2 WAN links. One is 1GE and another is 10GE.
5) We will use 3 IP subnet at this new DC (Nexus). 172.16.7.0/24, 172.16.8.0/24 and 172.16.200.0/24. Do we need any kind of summary command in the physical interface between these two N5K and also with upstream L3 devices while configuring EIGRP. Kindly share me you comments.
Thanks again.
Adnan
Ok.
4) It will not be ECMP cause one of the link is much faster (10x).
5) It depends on your design and over all DC addressing scheme. By just looking at it, you can only combine (summarize) 172.16.7.0/24 and 172.16.8.0/24 into a /23.
HTH,
jerry
Hi Jerry,
Thanks.
4) It is still ok with us if this is not doing ECMP and we will treat the other 1GE link as the Redundant link in case of 10GE link failure.
5) Ok. Actually in DC1 and DC2 we have "no auto summary" command in L3 device for Eigrp. That is the reason I asked you this question. As I have doubt whether EIGRP will automatically summarize the subnet to '/16' instead of 3 '/24' subnet. kindly suggest me how can I achieve this "no auto summary" in N5K.
Thanks for your comments and suggestions.
I will check the configuration today with our test bed and let you know for any update.
Adnan
For 5), EIGRP "no auto-summary" is on by default, you cannot turn it off in Nexus.
HTH,
jerry
Thanks a lot Jerry. I will check today and let you know. Thanks.
Hi Jerry,
I have configured both my N5K and one L3 uplink switch with EIGRP routing. I have also configured HSRP in 2xN5K for it local Vlan77. Here is the jist.
                          [N5K-1]
[PC1] -- [L3SW]    |   | ||     [N2K] -- [PC1]
                          [N5K-2]
Here,
     PC1 in Vlan78 (IP:172.16.78.10, GW:172.16.78.254)
     PC2 in Vlan77 in N5K with HSRP (IP:172.16.77.10, GW:172.16.77.1)
Problem:
     - From PC1, I can ping L3SW gateway, N5K L3 Interfaces, ---> but I cant ping HRSP GW in N5K (172.16.77.1) and PC1 under N5K (172.16.77.10).
     - From PC2, I can ping N5K HSRP gateway 172.16.77.1. ---> but I cant ping any thing else.
I wonder if there is any STP issue or VLAN allow inssue. I am also not sure about EIGRP configuration in N5K.
I am sharing the configuration of all the N5K with some vpc, hsrp output. (File attachment link is not showing so I have paste the configuration here).
Appreciate if you can help.
Thanks.
Adnan
N5K-01+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
sh run
!Command: show running-config
!Time: Fri Aug  3 04:19:11 2012
version 5.2(1)N1(1)
logging level feature-mgr 0
hostname MT-DC-DIST-SW01
feature telnet
cfs ipv4 distribute
cfs eth distribute
feature eigrp
feature udld
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature lldp
feature vtp
feature fex
username admin password 5 $1$kDmLSJK8$/9gGfUigMG3N6d.H4xPPF1  role network-admin
[7m--More-- [27m
banner motd #Nexus 5000 Switch
ip domain-lookup
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
system qos
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type qos input fcoe-default-in-policy
  service-policy type network-qos fcoe-default-nq-policy
vtp mode transparent
[7m--More-- [27m
fex 101 [K
  pinning max-links 1
  description "MT-DC-N2K-SW01"
  type N2248TP-E
snmp-server user admin network-admin auth md5 0xd8e825eac236793619b170efc28d4bb7
priv 0xd8e825eac236793619b170efc28d4bb7 localizedkey
vrf context management
  ip route 172.16.0.0/16 172.31.1.254
vrf context VPC_KEEPALIVE
vlan 1
vlan 2
  name NATIVE-VLAN
vlan 3
  name VPC-KEEPALIVE
vlan 77
  name VIR-VLAN-77
vpc domain 1
  peer-keepalive destination 172.31.77.2 source 172.31.77.1 vrf default
  delay restore 150
  peer-gateway
  auto-recovery
port-profile default max-ports 512
[7m--More-- [27m
[K
interface Vlan1
interface Vlan3
  no shutdown
  no ip redirects
  ip address 172.31.77.1/30
interface Vlan77
  no shutdown
  no ip redirects
  ip address 172.16.77.2/24
  hsrp version 2
  hsrp 77
    name VIR-VLAN-77
    preempt delay minimum 60
    priority 150
    ip 172.16.77.1
interface port-channel1
  switchport mode trunk
  switchport trunk native vlan 2
[7m--More-- [27m
  switchport trunk allowed vlan 2-50,77
  spanning-tree port type network
  vpc peer-link
interface port-channel101
  description Connected to MT-DC-N2K-SW01
  switchport mode fex-fabric
  switchport trunk allowed vlan 77
  fex associate 101
  vpc 101
interface port-channel1010
interface Ethernet1/1
  channel-group 1 mode active
interface Ethernet1/2
[7m--More-- [27m
interface Ethernet1/3
  speed 1000
interface Ethernet1/4
interface Ethernet1/5
  description *** Connected to UPLINK-SW ***
  no switchport
  speed 1000
  ip address 172.31.77.9/30
interface Ethernet1/6
  description *** Connected to N5K-02 ***
  no switchport
  speed 1000
  ip address 172.31.77.5/30
[7m--More-- [27m
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
  fex associate 101
  channel-group 101
interface mgmt0
  ip address 172.31.1.222/24
interface Ethernet101/1/1
  description Connected to Server
  switchport access vlan 200
interface Ethernet101/1/2
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
interface Ethernet101/1/12
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet101/1/17
interface Ethernet101/1/18
interface Ethernet101/1/19
interface Ethernet101/1/20
[7m--More-- [27m
interface Ethernet101/1/21
interface Ethernet101/1/22
interface Ethernet101/1/23
interface Ethernet101/1/24
interface Ethernet101/1/25
interface Ethernet101/1/26
interface Ethernet101/1/27
interface Ethernet101/1/28
interface Ethernet101/1/29
interface Ethernet101/1/30
interface Ethernet101/1/31
interface Ethernet101/1/32
interface Ethernet101/1/33
interface Ethernet101/1/34
interface Ethernet101/1/35
interface Ethernet101/1/36
interface Ethernet101/1/37
interface Ethernet101/1/38
interface Ethernet101/1/39
interface Ethernet101/1/40
interface Ethernet101/1/41
interface Ethernet101/1/42
interface Ethernet101/1/43
interface Ethernet101/1/44
interface Ethernet101/1/45
interface Ethernet101/1/46
interface Ethernet101/1/47
interface Ethernet101/1/48
  switchport access vlan 77
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.2.1.N1.1.bin
boot system bootflash:/n5000-uk9.5.2.1.N1.1.bin
router eigrp Test1
  autonomous-system 100
MT-DC-DIST-SW01# sh fex
  FEX         FEX           FEX                       FEX
Number    Description      State            Model            Serial
101  MT-DC-N2K-SW01                Online   N2K-C2248TP-E-1GE   SSI154104YJ
MT-DC-DIST-SW01# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : failed
Type-2 inconsistency reason       : QoSMgr Qos configuration incompatible
vPC role                          : secondary
Number of vPCs configured         : 49
Peer Gateway                      : Enabled
Peer gateway excluded VLANs     : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Enabled (timeout = 240 seconds)
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     2-3,77
[7m--More-- [27m
[K
vPC status
id     Port        Status Consistency Reason                     Active vlans
101    Po101       up     success     success                    -
102400 Eth101/1/1  down*  Not         Consistency Check Not      -
                          Applicable  Performed
102401 Eth101/1/2  down*  Not         Consistency Check Not      -
102402 Eth101/1/3  down*  Not         Consistency Check Not      -
102403 Eth101/1/4  down*  Not         Consistency Check Not      -
102404 Eth101/1/5  down*  Not         Consistency Check Not      -
102405 Eth101/1/6  down*  Not         Consistency Check Not      -
102406 Eth101/1/7  down*  Not         Consistency Check Not      -
102407 Eth101/1/8  down*  Not         Consistency Check Not      -
102408 Eth101/1/9  down*  Not         Consistency Check Not      -
[7m--More-- [27m
102409 Eth101/1/10 down*  Not         Consistency Check Not      -
102410 Eth101/1/11 down*  Not         Consistency Check Not      -
102411 Eth101/1/12 down*  Not         Consistency Check Not      -
102412 Eth101/1/13 down*  Not         Consistency Check Not      -
102413 Eth101/1/14 down*  Not         Consistency Check Not      -
102414 Eth101/1/15 down*  Not         Consistency Check Not      -
102415 Eth101/1/16 down*  Not         Consistency Check Not      -
102416 Eth101/1/17 down*  Not         Consistency Check Not      -
102417 Eth101/1/18 down*  Not         Consistency Check Not      -
102418 Eth101/1/19 down*  Not         Consistency Check Not      -
102419 Eth101/1/20 down*  Not         Consistency Check Not      -
[7m--More-- [27m
102420 Eth101/1/21 down*  Not         Consistency Check Not      -
102421 Eth101/1/22 down*  Not         Consistency Check Not      -
102422 Eth101/1/23 down*  Not         Consistency Check Not      -
102423 Eth101/1/24 down*  Not         Consistency Check Not      -
102424 Eth101/1/25 down*  Not         Consistency Check Not      -
102425 Eth101/1/26 down*  Not         Consistency Check Not      -
102426 Eth101/1/27 down*  Not         Consistency Check Not      -
102427 Eth101/1/28 down*  Not         Consistency Check Not      -
102428 Eth101/1/29 down*  Not         Consistency Check Not      -
102429 Eth101/1/30 down*  Not         Consistency Check Not      -
102430 Eth101/1/31 down*  Not         Consistency Check Not      -
102431 Eth101/1/32 down*  Not         Consistency Check Not      -
[7m--More-- [27m
102432 Eth101/1/33 down*  Not         Consistency Check Not      -
102433 Eth101/1/34 down*  Not         Consistency Check Not      -
102434 Eth101/1/35 down*  Not         Consistency Check Not      -
102435 Eth101/1/36 down*  Not         Consistency Check Not      -
102436 Eth101/1/37 down*  Not         Consistency Check Not      -
102437 Eth101/1/38 down*  Not         Consistency Check Not      -
102438 Eth101/1/39 down*  Not         Consistency Check Not      -
102439 Eth101/1/40 down*  Not         Consistency Check Not      -
102440 Eth101/1/41 down*  Not         Consistency Check Not      -
102441 Eth101/1/42 down*  Not         Consistency Check Not      -
102442 Eth101/1/43 down*  Not         Consistency Check Not      -
[7m--More-- [27m
102443 Eth101/1/44 down*  Not         Consistency Check Not      -
102444 Eth101/1/45 down*  Not         Consistency Check Not      -
102445 Eth101/1/46 down*  Not         Consistency Check Not      -
102446 Eth101/1/47 down*  Not         Consistency Check Not      -
102447 Eth101/1/48 down*  Not         Consistency Check Not      -
MT-DC-DIST-SW01# sh hrsp
Vlan77 - Group 77 (HSRP-V2) (IPv4)
  Local state is Active, priority 150 (Cfged 150), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 150
  Preemption Delay (Seconds) Minimum:60
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 0.491000 sec(s)
  Virtual IP address is 172.16.77.1 (Cfged)
  Active router is local
  Standby router is 172.16.77.3 , priority 100 expires in 0.172000 sec(s)
  Authentication text "cisco"
  Virtual mac address is 0000.0c9f.f04d (Default MAC)
  5 state changes, last state change 16:10:16
  IP redundancy name is VIR-VLAN-77 (cfgd)
MT-DC-DIST-SW01# sh spanning-tree su mmary
Switch is in rapid-pvst mode
Root bridge for: none
Port Type Default                        is disable
Edge Port [PortFast] BPDU Guard Default  is disabled
Edge Port [PortFast] BPDU Filter Default is disabled
Bridge Assurance                         is enabled
Loopguard Default                        is disabled
Pathcost method used                     is short
STP-Lite                                 is enabled
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0001                     0         0        0          1          1
VLAN0002                     1         0        0          1          2
VLAN0003                     1         0        0          1          2
VLAN0077                     1         0        0          1          2
4 vlans                      3         0        0          4          7
MT-DC-DIST-SW01# sh vla [23D [J
MT-DC-DIST-SW01# sh vla [Jn
VLAN Name                             Status    Ports
1    default                          active    Eth1/3, Eth1/4, Eth1/7, Eth1/8
                                                Eth1/9, Eth1/10, Eth1/11
                                                Eth1/12, Eth1/13, Eth1/14
                                                Eth1/15, Eth1/16, Eth1/17
                                                Eth1/18, Eth1/19, Eth1/20
                                                Eth1/21, Eth1/22, Eth1/23
                                                Eth1/24, Eth1/25, Eth1/26
                                                Eth1/27, Eth1/28, Eth1/29
                                                Eth1/30, Eth1/31
2    NATIVE-VLAN                      active    Po1, Eth1/1, Eth1/2, Eth1/3
3    VPC-KEEPALIVE                    active    Po1, Eth1/1, Eth1/2, Eth1/3
77   VIR-VLAN-77                      active    Po1, Eth1/1, Eth1/2, Eth1/3
                                                Eth101/1/48
VLAN Type  Vlan-mode
1    enet  CE
2    enet  CE
3    enet  CE
77   enet  CE
[7m--More-- [27m
[K
Remote SPAN VLANs
Primary  Secondary  Type             Ports
N5K-2++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
MT-DC-DIST-SW02# sh run
!Time: Fri Aug  3 04:20:51 2012
version 5.2(1)N1(1)
hostname MT-DC-DIST-SW02
feature telnet
cfs eth distribute
feature eigrp
feature udld
feature hsrp
feature lacp
feature vpc
feature lldp
feature vtp
feature fex
username admin password 5 $1$Q8KWr8VJ$Fp2a8nL7YWdOf1VQdkcXS0  role network-admin
no password strength-check
ip domain-lookup
  match qos-group 1
  match qos-group 2
  match qos-group 2
  match qos-group 1
  match qos-group 2
  match qos-group 2
fex 101
  pinning max-links 1
  type N2248TP-E
snmp-server user admin network-admin auth md5 0xb54570ce73756454d188924d08435275
priv 0xb54570ce73756454d188924d08435275 localizedkey
vlan 1
vlan 2
  name NATIVE-VLAN
vlan 3
  name VPC-KEEPALIVE
vlan 77
  name VIR-VLAN-77
vpc domain 1
  peer-keepalive destination 172.31.77.1 source 172.31.77.2 vrf default
  delay restore 150
  peer-gateway
  auto-recovery
interface Vlan1
interface Vlan3
  no shutdown
  no ip redirects
  ip address 172.31.77.2/30
interface Vlan77
  no shutdown
  description *** Connected to HC-TestGW ***
  no ip redirects
  ip address 172.16.77.3/24
  hsrp version 2
  hsrp 77
    name VIR-VLAN-77
    ip 172.16.77.1
  vpc peer-link
  fex associate 101
  vpc 101
  speed 1000
[7m--More-- [27m
  no switchport
  speed 1000
  ip address 172.31.77.13/30
  description *** Connected to N5K-01 ***
  no switchport
  speed 1000
  ip address 172.31.77.6/30
[7m--More-- [27m
  fex associate 101
  channel-group 101
interface mgmt0
  ip address 172.31.1.223/24
line console
line vty
router eigrp Test1
MT-DC-DIST-SW02#     sh fex
  FEX         FEX           FEX                       FEX
MT-DC-DIST-SW02# sh vpc
Legend:
vPC domain id                     : 1
vPC role                          : primary
1    Po1    up     2-3,77
vPC status
MT-DC-DIST-SW02#   sh s  [Jhr  [Jsrp
  Local state is Standby, priority 100 (Cfged 100), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 100
  Next hello sent in 2.397000 sec(s)
  Active router is 172.16.77.2, priority 150 expires in 8.428000 sec(s)
  Standby router is local
  1 state changes, last state change 15:59:27
MT-DC-DIST-SW02# sh spanning-tree su [Jmmary
Root bridge for: VLAN0001-VLAN0003, VLAN0077
STP-Lite                                 is enabled
VLAN0001                     0         0        0          1          1
VLAN0002                     0         0        0          2          2
VLAN0003                     0         0        0          2          2
VLAN0077                     0         0        0          2          2
4 vlans                      0         0        0          7          7
interface vlan 77
HTH,
jerry
