WAN speed limitations
linedpaper
Trying to find a good fit for a home router.  My goal is to have a full IOS setup to assist in my studies and I'm on to the router/firewall piece.  Was looking at an 871 as I could accomplish the fw and routing in this device, however in my reading it seems that the max wan speed I'm going to get is around 12mbps.  Is this accurate and if so, what's the cheapest device I can get that can handle my 45/5 connection at home?  I'm fine with an EOL device such as the 871 as this is just for home, but I don't want to degrade my WAN connection at all.  I was hoping for fanless and was also hoping for cheaper than I'm finding the 881's for right now.  Any suggestions or advice would be much appreciated.
Tim
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Software router performance, such as for an 871, very much depends on what your traffic looks like and your device configuration.  Cisco notes the performance for the 860 (same 25 Kpps as the 870 series) ranges from 16.8 Mbps (min packet size) to 198 Mbps (max packet size) - that's just packet forwarding.  (Cisco also notes the 860 series can deliver up to 27 Mbps for IMIX traffic, @75% CPU, and with PAT.)  Cisco recommends an 860 for up to 4 Mbps (duplex) bandwidth.
The 890 series is recommended, by Cisco, for only 15 Mbps (duplex), but it's also noted as delivering 45 Mbps for IMIX traffic, @75% CPU and with NAT/QoS/ACL.  I.e., the 890 might work for you.
BTW, for 45/5 (or 25 Mbps duplex), Cisco recommends a 1941 or 2901.
