WAN static no ISP
pcfreak49
Dear All
I know who can help me to configure my cisco 892 router
want a static ip address assigned to the interface because
and I have no more internet on the router
because am working on my network academy for CCENT
Please help!
28 Replies 28
I did and still does not work
could you post a topology diagram.
Regards.
Alain
did it have a static route to the ISP router Added
ip route 0.0.0.0 0.0.0.0 84.197.160.1
but you can also do this for another wan interface?
I don't understand what you mean.
Could you also answer my previous question which is post a topology diagram.
Regards.
Alain
Did you do a traceroute to see how far you can go?
Does your remote connection has a route to your network?
Eugen
the router is connected to a cable / modem, the router will give a static ip address
after a time I was no more internet, if I put a static ip address
when it sends a diagram how it looks the router is connected to a cable / modem, the router will give a static ip address
Your vlan 2 interface has a public ip address, but is configured as an inside interface, why?
Your dhcp pool say "ip dhcp pool Wireless-CISCO_R1_2.4GHZ_Private" , but you use a public ip???
Also did you try to disable ipv6 configs for testing?
Eugen
vlan 2 has private ip address that is used for wireless clients
the dhcp pool for a private client ip address to give
and will disable ipv6
Your vlan 2 has public ip address 20.20.x.x and the dhcp pool is public network as well.
The private address space is specified in this page
http://en.wikipedia.org/wiki/Private_network
Eugen
I have the ip address of vlan 2 changes to 10.20.10.1 255.255.255.0
and the ip dhcp pool Wireless CISCO_R1_2.4GHZ_Private
has a range of 10.20.10.0 but the problem persists after a few hours I just do not have internet connection more
how can you fix that ?
What cable modem are you using? Is it just modem or modem/router?
it's just a telenet modem interface on dhcp if I put it always works but that is not the intention that would interface to set static ip address?
Check how long is the lease time for that IP address. If your internet connection terminates after few hours it may be that the lease time is expired for that IP and since you disabled dhcp you won't get a new lease on that IP or a new IP address.
these are the data from the dhcp lease
R2 # sh dhcp lease
Temp IP addr: 84,197,164,129 for peer on Interface: GigabitEthernet0
Temp sub net mask: 255.255.240.0
DHCP Lease server: 195.130.137.3, state: 5 Bound
DHCP transaction id: 1E92
Lease: 7200 secs, Renewal: 3600 secs, REBIND: 3660 secs
Temp default-gateway addr: 84.197.160.1
Next timer fires after: 0:49:50
Retry count: 0 Client-ID: c84c.75a2.1722
Client-ID hex dump: C84C75A21722
Hostname: R2
how can you change to a static ip address?
