WAN static no ISP
pcfreak49
Dear All
I know who can help me to configure my cisco 892 router
want a static ip address assigned to the interface because
and I have no more internet on the router
because am working on my network academy for CCENT
Please help!
28 Replies 28
cadet alain
interface x/x
ip address x.x.x.x y.y.y.y      where x.x.x.x is the IP and y.y.y.y is the subnet mask
no shut
Regards.
Alain
okay I did
but can not connect to the Internet
Do you have a default gateway pointing at the next hop router towards your ISP?
yes I did make that can not connect to the Internet ?
From where can't you connect and how do you test connectivity?
Post your config and by the way you said you didn't have internet anymore in your first post and now you say you can't connect to internet ?
Regards.
Alain
no I can not connect to the Internet
This is the running-config
is there a modem connected to Gigabit 0/0 ?
Can you ping 8.8.8.8 from the router ? if so can you  ping 8.8.8.8 from a wired client getting a dhcp address?
Regards.
Alain.
yes the Gigabit 0/0 is connected to the modem
and the wired client, you get a dhcp
these are the data wired client
and can ping the router to 10.10.10.1
you didn't answer this:
Can you ping 8.8.8.8 from the router ? if so can you  ping 8.8.8.8 from a wired client?
if not verify NAT is working: sh ip nat translation
Regards.
Alain.
no I can not ping from the router to 8.8.8.8
nor from the wired client PC to 8.8.8.8
This configuration is NAT
access-list 199 permit icmp any any
no service timestamp debug
logging console debug
do debug ip packet detail 199
do ping 84.197.160.1 rep 2
Post the output of the debug
Regards.
Alain
I did that and this is the output
Rick Morris
Level 6
Level 6
To direct traffic as you are suggesting you need an exit interface to send the traffic to.
If you are sitting on FastEthernet 0/0 with an IP of 10.0.0.1 255.255.255.0
You will need an exit interface such as FastEthernet 0/1 with an IP address of 192.168.0.1 255.255.255.0
You would then create a static route like ip route 0.0.0.0 0.0.0.0 FastEthernet 0/1  (or you need a next hop address which would be the far end on the other side of the exit interface)
This will take all traffic and send it out FastEthernet 0/1
This is just an example.  To customize for you we need to know some more specifics on what you are trying to do.
ebarticel
Level 4
Level 4
Maybe if you remove the default gateway and put default static pointing to the default gateway.
ip route 0.0.0.0 0.0.0.0 84.x.x.x
Hope this helps
Eugen
