07-14-2008 05:18 AM - edited 03-03-2019 10:42 PM
want to connect my 4 remote offices by tech. to share data and voice.
07-14-2008 05:23 AM
If you're the end user, you should locate a reliable cisco partner.
He/she will configure VPN over the internet using cisco routers.
07-14-2008 06:00 AM
basically one of my friend suggested to use CISCO Router 1841 n Sitch 2960 n 3500 with IP Phones with a connectivity using Wireless Access Point, UTM box and IPPBX....to me confusing? how does it actually work??
I stay in Kolkata, India,I need to know local Cisco Partner whereabouts as well
07-14-2008 08:42 AM
Hi, the details of the routers to use can be very different and can be defined only after an analysis.
You can get the official list of cisco partners on this website, under "partner central".
Please rate post if it helps!
