%WARNING: Signature not found in file flash:/c850-advsecurityk9-mz.124-15.T16.bin.
Oerlikon_NZ
Can anyone shed any light on the following %WARNING message?  The router(Cisco 857) appears to be boot, and operate normally.
I have tried formating the flash, re-downloading and FTP uploading the image, and also tried the latest image c850-advsecurityk9-mz.124-15.T17.bin, but this warning message persists.  I know it's possible to disable the verify option, but this is bugging me.
R1#copy ftp flash
Address or name of remote host [192.168.1.48]?
Source filename [c850-advsecurityk9-mz.124-15.T16.bin]? adsl_alc_20190.bin
Destination filename [adsl_alc_20190.bin]?
Accessing ftp://192.168.1.48/adsl_alc_20190.bin...
Loading adsl_alc_20190.bin !!!!
[OK - 1002424/4096 bytes]
1002424 bytes copied in 15.034 secs (66677 bytes/sec)
EN_WarwickTest#reload
System configuration has been modified. Save? [yes/no]: yes
Building configuration...
[OK]
Verifying file integrity of flash:/c850-advsecurityk9-mz.124-15.T16.bin
Signature not present. Proceed with verify? [confirm]
R1#verify flash:c850-advsecurityk9-mz.124-15.T16.bin
Verifying file integrity of flash:c850-advsecurityk9-mz.124-15.T16.bin
Embedded hash not found in file flash:c850-advsecurityk9-mz.124-15.T16.bin.
File system hash verification failed for file flash:c850-advsecurityk9-mz.124-15.T16.bin(No such file or directory).
R1#verify /md5 flash:c850-advsecurityk9-mz.124-15.T16.bin ?
  WORD  Expected md5 signature
  <cr>
............................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
verify /md5 (flash:c850-advsecurityk9-mz.124-15.T16.bin) = ccd5650ee365c747ac78d9130abd087c
R1#$ityk9-mz.124-15.T16.bin ccd5650ee365c747ac78d9130abd087c
Verified (flash:c850-advsecurityk9-mz.124-15.T16.bin) = ccd5650ee365c747ac78d9130abd087c
2 Accepted Solutions
Ivan Shirshin
That's a known bug CSCsr09040 - "verify :file" shows "Embedded hash not found" for Linux builds.
Workaround is to use the verify /md5 command to only run md5 on the file. Compare this value to the value posted on Cisco.com for the image.
Bug is fixed starting with 12.4(22)T.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
the bug I mentioned in post below is dependant on whether Linux was used or Solaris to build the image. If Solaris was used, you want see this warning.
Kind Regards,
Ivan
Kind Regards,
Ivan
Oerlikon_NZ
There are no WARNING messages with the original IOS image
R1#copy ftp flash
Address or name of remote host []?
?Host name or address not specified
%Error parsing filename (Unknown error 0)
R1#copy ftp flash
Address or name of remote host []? 192.168.1.48
Source filename []? c850-advsecurityk9-mz.124-6.T9.bin
Destination filename [c850-advsecurityk9-mz.124-6.T9.bin]?
Accessing ftp://192.168.1.48/c850-advsecurityk9-mz.124-6.T9.bin...
Loading c850-advsecurityk9-mz.124-6.T9.bin !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 11158968/4096 bytes]
11158968 bytes copied in 134.357 secs (83055 bytes/sec)
Verifying file integrity of flash:/c850-advsecurityk9-mz.124-6.T9.bin.....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
Embedded Hash   MD5 : 334CD08AA3FAD48C76DA73EF70D64E3A
Computed Hash   MD5 : 334CD08AA3FAD48C76DA73EF70D64E3A
CCO Hash        MD5 : C6A5C5416266E70E6E02AB0CE9795BDC
Signature Verified
Kind Regards,
Ivan
Kind Regards,
Ivan
Ivan Shirshin
Kind Regards,
Ivan
Kind Regards,
Ivan
