warp/public/ folder
iqbalkhan
Many documentation are stored in http://www.cisco.com/warp/public/104/1.html
like example if i want to routing protocol ospf then go to the link.
but if i first browse http://www.cisco.com/warp/public for to see the content then i can not get it. so how I know or access to the link to see the full documentation.
thanks
biplob
paolo bevilacqua
You cannot browse directories on CCO. If you want to see all what is available, either use the documentation index, or use the search function.
Please rate all useful posts using the scrollbox below!
You can also use the Cisco Connection Documentation, i find it great:
http://www.cisco.com/univercd/home/home.htm
HTH,
Mohammed Mahmoud.
