12-13-2011 10:44 AM - edited 03-04-2019 02:37 PM
We have an ASA5520 with VPN working fine.
outside host <---> ASA (10.100.0.2/24) <---> (10.100.0.1) Router (10.4.1.1/16) <---> (10.4.1.x) inside Host
We replaced the router, which upgraded the OS from v12.2 to v15.0. We duplicated all the addressing and routing statements from the old router. Now the VPN still connects but the outside host can't ping the inside host anymore. The outside host can't ping any further than the inside interface of the router (10.4.1.1). The Router can ping the outside host, so I know the tunnel is up.
I suspect there is a difference in the OS versions that is tripping us up. Perhaps in the way that we have reused the 10.x.x.x address range?
I've attached the router config.
Solved! Go to Solution.
12-13-2011 11:05 AM
Am I correct in understanding that 10.4.200.0 is the address range used for the VPN address pool? So the outside host is getting address 10.4.200.x and is attempting to ping 10.4.1.x?
Based on this assumption I am going to guess that the issue may be with this:
interface GigabitEthernet0/1
no ip proxy-arp
I suggest that you try enabling proxy arp on the inside interface. Give it a try and let us know if it helps.
Rick
12-13-2011 11:05 AM
no ip proxy-arp
Rick
12-13-2011 12:16 PM
Your assumption is correct about the address range. The ip proxy-arp solved the big problem. Thank you!
We have some other issues because our network is more complicated than I presented. I'll post a new entry if we run into any more road blocks.
12-13-2011 03:34 PM
I am glad that my suggestion pointed you to a successful solution of your problem. Thank you for using the rating system to mark the question as answered (and thanks for the points). It makes the forum more useful when people can read about an issue and can know that a solution was found. Your marking has contributed to this process.
This forum is an excellent resource and I encourage you to continue to use it and to post questions when you run into issues.
Rick
12-13-2011 05:09 PM
Rick rules
