Web Pages Not Loading - ip tcp adjust-mss of No Effect
alex.brown
I've been having a serious challenge getting certain web pages to load on windows clients behind a Cisco 1811 router.
Regardless of the browser, whenever I try to go to certain sites, travel sites like expedia.com or www.flightcentre.ca, when I enter the flight information and click the Search button, the page just sits there, acting like it's looking for the information.  If I click the Back button and then click the Forward button, the data that I was searching for appears.
I've run run the ping tests as well as the mturoute.exe tool and they both indicate that the mtu is 1500, however, that doesn't work.
C:\>ping -f -l 1472 www.dslreports.com
Pinging www.dslreports.com [209.123.109.175] with 1472 bytes of data:
Request timed out.
Reply from 209.123.109.175: bytes=1472 time=57ms TTL=52
Reply from 209.123.109.175: bytes=1472 time=101ms TTL=52
Reply from 209.123.109.175: bytes=1472 time=216ms TTL=52
Ping statistics for 209.123.109.175:
    Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
    Minimum = 57ms, Maximum = 216ms, Average = 124ms
C:\>mturoute -m 1500 www.expedia.ca
* ICMP Fragmentation is not permitted. *
* Speed optimization is enabled. *
* Maximum payload is 1500 bytes. *
+ ICMP payload of 1472 bytes succeeded.
- ICMP payload of 1473 bytes is too big.
Path MTU: 1500 bytes.
C:\>
I've tried setting the MSS to every recommended size, such as 1300, 536, and many, many, many others.  Nothing is working.
Here's a copy of the relevant parts of the config:
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
ip address dhcp
shutdown
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet1
ip address dhcp
ip nat outside
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 2$$ES_LAN$
ip address 192.168.112.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
no ip forward-protocol nd
ip route 10.5.117.0 255.255.255.0 192.168.112.2
ip route 0.0.0.0 0.0.0.0 dhcp
ip nat translation timeout 2
ip nat translation tcp-timeout 2
ip nat translation udp-timeout 2
ip nat translation icmp-timeout 2
ip nat inside source route-map primary interface FastEthernet0 overload
ip nat inside source route-map secondary interface FastEthernet1 overload
route-map primary permit 10
match ip address 110
match interface FastEthernet0
route-map secondary permit 10
match interface FastEthernet1
I would be tremendously grateful if someone could help me resolve this issue and so would the users.
Alex,
To me, the TCP connection simply stalls. There are no lost packets indicated, retransmissions, anything.
I noticed you are using pretty aggressive NAT timeouts. In theory, they could result in the NAT entries being aged out prematurely, and replies unable to be forwarded back to your PC. Can you remove all of them for now and re-test your config?
Best regards,
Peter
8 Replies 8
Peter Paluch
Hi Alex,
Let's try to find out the real MTU using the router's own methods.
Use the extended ping as indicated in this example:
Router# ping
Protocol [ip]:
Target IP address: 87.197.31.42
Repeat count [5]: 1
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]: yes
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: v
Loose, Strict, Record, Timestamp, Verbose[V]:
Sweep range of sizes [n]: y
Sweep min size [36]: 1450
Sweep max size [18024]: 1500
Sweep interval [1]:
Sending 51, [1450..1500]-byte ICMP Echos to 87.197.31.42, timeout is 2 seconds:
Packet sent with the DF bit set
Reply to request 0 (75 ms) (size 1450)
Reply to request 1 (76 ms) (size 1451)
Reply to request 2 (75 ms) (size 1452)
Reply to request 3 (76 ms) (size 1453)
Reply to request 4 (75 ms) (size 1454)
Reply to request 5 (84 ms) (size 1455)
Reply to request 6 (67 ms) (size 1456)
Reply to request 7 (84 ms) (size 1457)
Reply to request 8 (76 ms) (size 1458)
Reply to request 9 (75 ms) (size 1459)
Reply to request 10 (76 ms) (size 1460)
Reply to request 11 (75 ms) (size 1461)
Reply to request 12 (76 ms) (size 1462)
Reply to request 13 (67 ms) (size 1463)
Reply to request 14 (76 ms) (size 1464)
Reply to request 15 (67 ms) (size 1465)
Reply to request 16 (75 ms) (size 1466)
Reply to request 17 (76 ms) (size 1467)
Reply to request 18 (75 ms) (size 1468)
Reply to request 19 (76 ms) (size 1469)
Reply to request 20 (84 ms) (size 1470)
Reply to request 21 (75 ms) (size 1471)
Reply to request 22 (84 ms) (size 1472)
Reply to request 23 (76 ms) (size 1473)
Reply to request 24 (75 ms) (size 1474)
Reply to request 25 (76 ms) (size 1475)
Reply to request 26 (75 ms) (size 1476)
Reply to request 27 (76 ms) (size 1477)
Reply to request 28 (75 ms) (size 1478)
Reply to request 29 (76 ms) (size 1479)
Reply to request 30 (75 ms) (size 1480)
Reply to request 31 (84 ms) (size 1481)
Reply to request 32 (67 ms) (size 1482)
Reply to request 33 (76 ms) (size 1483)
Reply to request 34 (84 ms) (size 1484)
Reply to request 35 (75 ms) (size 1485)
Reply to request 36 (76 ms) (size 1486)
Reply to request 37 (75 ms) (size 1487)
Reply to request 38 (76 ms) (size 1488)
Reply to request 39 (75 ms) (size 1489)
Reply to request 40 (75 ms) (size 1490)
Reply to request 41 (76 ms) (size 1491)
Reply to request 42 (75 ms) (size 1492)
Request 43 timed out (size 1493)
Request 44 timed out (size 1494)
Request 45 timed out (size 1495)
Request 46 timed out (size 1496)
Request 47 timed out (size 1497)
Request 48 timed out (size 1498)
Request 49 timed out (size 1499)
Request 50 timed out (size 1500)
Success rate is 84 percent (43/51), round-trip min/avg/max = 67/75/84 ms
In this example, it is visible that the packet size becomes problematic after 1492B.
When performing this test, try using an external IP address which should be available with a normal MTU of 1500B. You may use the IP address 158.193.138.40 (a server of mine).
Please let us know the results! It is also possible we will have to modify the IP MTU on the egress interface Fa1.
Best regards,
Peter
Hi Peter,
Thanks for your reply.
This is the output I received from the router:
Router#ping
Protocol [ip]:
Target IP address: 184.31.252.137 <---- this is www.expedia.com
Repeat count [5]: 1
Sweep interval [1]:
Sending 51, [1450..1500]-byte ICMP Echos to 184.31.252.137, timeout is 2 seconds:
Reply to request 0 (92 ms) (size 1450)
Reply to request 1 (88 ms) (size 1451)
Reply to request 2 (88 ms) (size 1452)
Reply to request 3 (88 ms) (size 1453)
Reply to request 4 (88 ms) (size 1454)
Reply to request 6 (88 ms) (size 1456)
Reply to request 7 (88 ms) (size 1457)
Reply to request 8 (92 ms) (size 1458)
Reply to request 9 (88 ms) (size 1459)
Reply to request 10 (92 ms) (size 1460)
Reply to request 11 (88 ms) (size 1461)
Reply to request 12 (88 ms) (size 1462)
Reply to request 13 (88 ms) (size 1463)
Reply to request 14 (92 ms) (size 1464)
Reply to request 15 (88 ms) (size 1465)
Reply to request 16 (92 ms) (size 1466)
Reply to request 17 (88 ms) (size 1467)
Reply to request 18 (88 ms) (size 1468)
Reply to request 19 (88 ms) (size 1469)
Reply to request 20 (88 ms) (size 1470)
Reply to request 21 (88 ms) (size 1471)
Reply to request 22 (88 ms) (size 1472)
Reply to request 23 (88 ms) (size 1473)
Reply to request 24 (88 ms) (size 1474)
Reply to request 25 (92 ms) (size 1475)
Reply to request 26 (88 ms) (size 1476)
Reply to request 27 (88 ms) (size 1477)
Reply to request 28 (88 ms) (size 1478)
Reply to request 29 (92 ms) (size 1479)
Reply to request 30 (88 ms) (size 1480)
Reply to request 31 (88 ms) (size 1481)
Reply to request 32 (88 ms) (size 1482)
Reply to request 33 (88 ms) (size 1483)
Request 34 timed out (size 1484)
Reply to request 35 (88 ms) (size 1485)
Reply to request 36 (88 ms) (size 1486)
Reply to request 37 (88 ms) (size 1487)
Reply to request 38 (88 ms) (size 1488)
Reply to request 39 (88 ms) (size 1489)
Reply to request 40 (92 ms) (size 1490)
Reply to request 41 (88 ms) (size 1491)
Reply to request 42 (92 ms) (size 1492)
Reply to request 43 (88 ms) (size 1493)
Reply to request 44 (88 ms) (size 1494)
Reply to request 45 (92 ms) (size 1495)
Reply to request 46 (88 ms) (size 1496)
Reply to request 48 (88 ms) (size 1498)
Reply to request 49 (88 ms) (size 1499)
Reply to request 50 (88 ms) (size 1500)
Success rate is 96 percent (49/51), round-trip min/avg/max = 84/88/92 ms
So, looks like the same result.
Alex
lgijssel
Level 9
Level 9
Hi Alex,
Looks like MTU size is not the issue here. Expl:
You are able to ping with a payload of 1472 bytes with DF set.
Add 20 bytes of IP header and 8 bytes of ICMP header to this and you are at 1500 bytes.
More will not be possible.
Perhaps you can verify the browser settings, especially the security-related ones.
Other optins: Try with a different browser or make a capture of the traffic with WireShark and post it for analysis.
regards,
Leo
Thanks for your reply, Leo,
This happens with all three major browsers, IE, firefox, and Chrome, on various clients such as Mac, Windows XP, Vista, and 7.  The Windows XP machine I'm using as a test doesn't have this issue outside of this location.
I will work on getting a Wireshark capture.
Alex
Leo,
Regarding the 1472B you have indicated - just to make sure: the size argument for Cisco's ping command specifies the total IP packet length including its IP header, ICMP header and ICMP body. Specifying a ping with the size argument of 1472B produces an 1472B IP packet with 20B IP header, 8B ICMP header and 1444B ICMP body.
This behavior changes wildly between different operating systems. Under Linux, the ping command does not consider the ICMP+IP header sizes when specifying the length of the packet, and the produced packet is 28B longer than what is specified. On IOS and presumably Windows, the behavior is to produce a packet whose total size is identical to the specified argument.
Considering the output Alex provided, however, it seems that the MTU is indeed not the problem here.
Best regards,
Peter
Leo,
Here's a capture of me going searching for a flight on www.flightcentre.ca.  The results page never loads.
When a Linksys router is used to replace the Cisco router, these issues do not occur.
*Note:  The capture contains the real IP address(es) of the laptop/subnet which I had changed in the config I originally posted.
Alex
Alex,
Best regards,
Peter
THAT DID IT!!!  I thought I had removed those settings in the past.  I didn't set this router up originally.
Peter, thank you very much!!  Leo, thank you very much for your insight as well!  You all make a great team!!
Thank you, thank you, thank you!
Alex
