Web User Interface for day zero routing
lam32123
I have configured host name, passwords, and GigabitEthernet0 (management port) to ip address to 192.168.1.1  !   That seems to work as a basic configuration.  According to chapter 5 of  "Cisco 4000 Series ISR Software Configuration Guide"  I tried setting up factory default device using WebUI as shown on page 31, but Firefox and Edge refused to connect.  (the network connection would configure and ping just fine, but browsers refused to connect even with firewall, virus, etc turned off)  I then tried using web user interface for day one setup on page 35 ----- with a static ip address on my laptop, I can actually connect to the router management port via my browser, it ask my username and password like it is suppose to, but never gives me the choice of basic or advanced mode setup or the GUI-base management tool !  The screen is titled Cisco Systems -----Accessing Cisco ISR4331/K9 "hostname" ----- it gives four choices 1) Show diagnostic log  2) Monitor the router  3) Show tech-support  4) Extended Ping.  The "Monitor the router" choice gives HTML access to the command line interface
Does anyone know a HTML command to start embedded GUI-based setup tool ????
6 Replies 6
do you have:
ip http server
ip http secure-server
configured globally on the router ?
it is configured
ip http server
ip http authentication local
Ruben Cocheno
@lam32123
You probably dont' have the full gui version files/folders to load up the nice and cool gui, you can download it on the Cisco website. If you are looking to configure something else feel free to ask.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
I have also configured host name, passwords, and GigabitEthernet0 (management port) to ip address to 192.168.1.1  !     but some issues i am facing when i visit racquets sites.
as suggested, make sure the necessary files are present in flash. What is the output of:
dir flash:
dir flash responds:
%Error opening bootflash:/flash (No such file or directory)
Now my question is ----- what should be there?  The router is new but I have reset router back to factory setting (several times) as I've looked for a solution
