Weird Default Route issue
David Lee
So i have a weird entry in my routing table that I cant figure out.  The one thing I do know is that its not supposed to be there.  Its a router off a router using the same protocol as the upstream router, BGP.   Ping and everything works, but its causing issues with trying to use another downstream router and redistribute BGP into either EIGRP or OSPF.
Router# sh ip route
Gateway of last resort is 10.10.200.252 to network 0.0.0.0
* 0.0.0.0/32 is subnetted, 1 subnets
B* 0.0.0.0 [20/0] via 10.10.200.252
Its the default route that is being learned from BGP, but I know its not supposed to show * 0.0.0.0/32    I have some other networks using the same model routers on a completely different segment that looks correct.
GGR-C2901-02#sh ip route
Gateway of last resort is 152.181.47.41 to network 0.0.0.0
B*    0.0.0.0/0 [2/0] via 152.181.47.41, 1w1d
This router looks correct.  Both routers are only running BGP at the moment.  This one has custom Distance due to the backup WAN solution, but that shouldn't affect how the default route appears.
It all works, its a bid odd.
David
7 Replies 7
Rob Cluett
Is there an ip route statement somewhere with the mask set to 255.255.255.255 rather than 0.0.0.0 ?
Example...
"ip route 0.0.0.0 255.255.255.255 10.10.200.252"
can you post the configs?
Could you please share a screenshot, also the last route displayed has an administrative distance of 2, is that correct?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
Im not sure what you want me to take a screenshot of.  I also explained what the distance of 2 was for.   That is on a completely separate system not even remotely connected to the one with the oddness.  I was just logging into that system to verify that BGP wasn't being wonky there too.  the AD of 2 is for the WAN failover solution for that particular config.
Your config looks fine, if it is not on production, you could try to refresh the route into the routing table:
clear ip route 0.0.0.0
or from the upstream router you could advertise a default route through the peering:
router bgp 7018
bgp log-neighbor-changes
no synchronization
neighbor 10.10.200.251 default-originate
Here are the upstream configs and the one is question.  The configs are vanilla outside of whats below as this is a completely new network not connected to the one that is working with no issues.
Upstream -
interface GigabitEthernet0/2
ip address 10.10.200.252 255.255.255.248
ip nat inside
duplex auto
speed auto
router bgp 7018
no synchronization
neighbor 10.10.200.251 remote-as 7020
network 10.2.5.0 mask 255.255.255.0
network 10.3.5.0 mask 255.255.255.0
network 192.168.5.0
network 10.5.5.0 mask 255.255.255.0
network 10.10.200.248 mask 255.255.255.248
network 0.0.0.0
redistribute connected
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 10.50.100.252
access-list 10 permit 192.168.0.0 0.0.255.255
access-list 10 permit 10.10.0.0 0.0.255.255
access-list 10 permit 10.100.0.0 0.0.255.255
Here is the one in question
interface FastEthernet0/0
ip address 10.10.200.251 255.255.255.248
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.10.42.251 255.255.255.0
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
router bgp 7020
no synchronization
neighbor 10.10.200.252 remote-as 7018
neighbor 10.10.42.252 remote-as 65000
I suspect that your issue is this statement in the BGP config of the uupstream router.
network 0.0.0.0
I would suggest that they should specify the mask for this network entry. When you have a network statement with no mask in BGP then BGP makes assumptions to use the default mask for that network and in this case that assumption may be causing the issue.
Rick
Rick
