11-13-2011 06:44 AM - edited 03-04-2019 02:15 PM
i received this syslog message on my cisco 3845 router
Nov 11 13:36:06.265 UTC: ASSERTION FAILED: file "../les/if_ng_dslsar_tx.c", line 385
does any one has an idea what is that message mean.
11-13-2011 03:59 PM
I believe that the assertion failed message is an indicator of a software problem. What version of code is running on this 3845? If it is covered by a maintenance contract the best alternative would be to open a case with Cisco TAC to figure out what to do about this.
Rick
11-13-2011 10:54 PM
Thanks Richard,
unfortunatly we don`t have maintanence contract but this is the show version if you have any idea
Internet#sh ver
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(6)T7, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 29-Mar-07 08:13 by khuie
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, 3800 Software (C3845-IPBASE-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
SemSem_Master uptime is 7 weeks, 1 day, 23 hours, 18 minutes
System returned to ROM by reload at 07:25:44 Cairo_L Sat Sep 24 2011
System restarted at 09:33:24 EST Sat Sep 24 2011
System image file is "flash:c3845-adventerprisek9-mz.124-6.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 221184K/40960K bytes of memory.
Processor board ID FCZ1109737D
12 DSL controllers
2 Gigabit Ethernet interfaces
12 ATM interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
