WFQ not default on ASR 1004 E1 interface?
eug123789
Hi all,
When i do a "show interface S1/0/0:0" on an ASR 1004, the queueing strategy was FIFO. i always thought that any interface that has a speed of less than 2.048 mbps would have WFQ applied? I try finding the fair-queue command but it is not there.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If interface WFQ isn't supported, likely you can do something similar with CBWFQ, although it might not support the "W" part of WFQ.
Sorry what do you mean it might not support the "W" part of WFQ?
Disclaimer
Posting
"W" is for weighted (uses IP Precedence to weigh flow's scheduling priority).
Fair-queue in CBWFQ pre-HQF works like interface fair-queue, in post-HQF it's just fair queuing.
