What cable is needed for HWIC-2CE1T1-PRI
jacinto1m
Does anybody know what cable is needed to for this module?
Any halp is much appreciated.
Juan Perez
Hi Juan ,
It depends on whether you are going to use it back-to-back (crossover) or connecting to TELCO (straight), here is an URL where you can find the pinouts:
http://www.trinityos.com/HARDWARE/common-cables.html#std-t1
Here is an URL for the cables:
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
Check "ISDN Connections".
Regards.
Hi Juan,
I can see that there are different types of cables:
RJ48-BNC
RJ48-RJ48
RJ48-twin-ax
RJ48-DB-15
How can I be sure which one is the right one for me?
Hi Juan,
It would be an RJ-48 straight cable RJ48-RJ48 when connecting to Smart Jack or crossover when back to back.
Regards.
