what does cryptographic-algorithm under key chain do in IOS ?
shlomim
looking into key chain commands over IOS/IOS XE I see that under the key, for example key 1 I can config the cryptographic-algorithm.
yet - I don't fully understand where does it take place.
to run a test I used the following configuration on all routers:
key chain EIGRP_MD5
key 1
key-string C1sc0
cryptographic-algorithm hmac-sha-256
router eigrp EIGRP
address-family ipv4 unicast autonomous-system 100
af-interface default
authentication mode md5
authentication key-chain EIGRP_MD5
exit-af-interface
topology base
exit-af-topology
network 0.0.0.0
exit-address-family
the routers do form neighbor adjacency with md5 despite that the key chain was meant for sha256.
so what am I missing ?
11 Replies 11
Md5 you config under eigrp is override the key algorithm'
So to make router use sha256 you need to change authc under eigrp to use also sha256
MHM
shlomim
thank you for your help and prompt response.
I understand that the configuration over EIGRP under the interface is the one that makes the decision.
what I don't understand is where does the command "cryptographic-algorithm hmac-sha-256" takes place ?
does it even takes place under eigrp ?
can I use eigrp without the command "authentication mode <md5/sha>" ? and it will use the key chain configuration ?
maybe this option is relevant for other things ? if so to what ?
this IOS XR router ?
this is IOS 15.7
In order let simplify
What eigrp need
Authentication mode (mandatory)
Authentication Key-chain (op)
If authentication mode use different than key-chain cryptography then eigrp will drop
Here come Q?
If authentication mode (mandatory) can I use it for sha256 without use cryptography sha256?
No you can not' both must be same algorithm.
So correct must be
key chain EIGRP_MD5
key 1
key-string C1sc0
router eigrp EIGRP
authentication mode md5 <<- this need to change to sha256
exit-af-interface
No! Without this command the router will not do any authentication even if you configure the key-chain.
The 'authentication mode' command is the main switch to enable authentication and must be set.
Hello
at present the authentication mode MD5 is set to all interfaces enabled for named eigrp using the key-chain you can however change the authentication mode to sha on all interfaces (af-default) or specific interfaces which will be more secure than the older MD5 - doing so will mean you will not require any key chain - in fact it isnt supported tbh when using sha
Kind Regards
Paul
Paul, thanks for your help
can you please clarify in which cases, I guess not EIGRP, do I need to use "cryptographic-algorithm hmac-sha-256/md5" under the key chain ?
Helllo
if you want to use SHA as a key-chain authentication then yes but why ?
SHA is a lot more secure so why create unnecessary cfg for your self - just enable sha at all interface level or specific interface level and do away with keychain all together as it’s not necessary and not supported
Kind Regards
Paul
Jens Albrecht
Level 4
Level 4
Hello @shlomim,
you need to specify the use of SHA256 for authentication to make it work.
Just tested and based on your example a working config looks as follows:
router eigrp EIGRP
   authentication mode hmac-sha-256 C1sco12345!
   authentication key-chain EIGRP_SHA256
  exit-af-interface
  topology base
  exit-af-topology
  network 0.0.0.0
 exit-address-family
This can be verified with the command 'show eigrp address-family ipv4 interfaces detail' which will include the line:
Authentication mode is HMAC-SHA-256, key-chain is "EIGRP_SHA256"
So indeed the key-chain is used for SHA256 authentication.
HTH!
Just a quick additional note in case you are wondering why you have to configure a key with the 'authentication mode hmac-sha-256 C1sco12345!' command.
HMAC-SHA-256 is a cryptographic technique that combines a hash function (in this case, SHA-256) with a secret key to provide both data integrity and authentication. So both sides must use the same key and the same key-chain in order to establish the neighborship.
