What features are available in c8300?
Translator
Community Manager
Community Manager
Hello. This time, you will be using C8300. The license is T0-E because it does not use SDWAN or IPSEC.
https://www.cisco.com/c/dam/m/en_us/products/software/dna-software/dna-software-sd-wan-routing-matrix/pdf/Cisco_DNA_Software_SD-WAN_and_Routing_Matrices.pdf
I'm checking the commands that can be used in the above URL, but in self-standing mode Is it okay if I check the function of Cisco DNA Software for Routing Feature Matrix, and in control mode, I check the function of Cisco DNA Software for SD-WAN Feature Matrix?
https://www.cisco.com/c/ja_jp/products/collateral/routers/catalyst-8300-series-edge-platforms/datasheet-c78-744088.html
If you look at the above data sheet, you can see that snmp can only use control mode, so please check it.
0 Replies 0
