What happens to existing traffic when I apply a service-policy to an interface
roward
Hi There,
I'm updating the QoS service-policies in use at my customer. Testing shows that the policies work.
My customer has asked if the change will be disruptive when it is applied to their main WAN routers.
Can anyone direct me to any information about what happens in the few seconds immediately after a service-policy is applied, including any commands to check the impact of the change?
For example, will there be any disruption as the CBWFQ etc. data structures are created...
Many Thanks,
Rob.
Julio E. Moisa
The traffic will not be disrupted, I suggest do that after business hours if possible.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
Juilo is correct in saying it wont be disruptive-- But I would say it depends on what the changes are.
BW allocation (Traffic shaping, Policing, Priority/llq queuing) etc can be disruptive if you experiencing congestion at the time of the change.
res
Paul
Kind Regards
Paul
