What happens to marked packets without qos trust on port?
Mike Assel
Level 4
Level 4
Hello.  Just wondering if the experts out there could confirm  something for me:  I have a switch that has been globally configured for  qos specifically for IP phones.  However one of the switchports I have  re-configured so it looks like this
interface FastEthernet0/36
description LAB
switchport mode access
switchport voice vlan 208
spanning-tree portfast
end
My  question is this: if a device that marks it's own packets (let's say  EF) is connected to this port, once the packets enter the port the  switch will remark them because there is no trust command configured on  the port, correct?  I would assume the default would be to zero?  The  reason I ask is that we have a network monitoring service that is setup  to monitor the qos markings of packets crossing our WAN and to notify us  if the packets get remarked.  I have confirgured the packets to be  marked EF on the device connected to the switchport mentioned above, so in my mind the markings should be getting changed and my service should see that, but it doesn't.  So I want to make sure I understand how it is supposed to work in the switch  before pointing the finger at the service.
John Blakley
Mike,
The default behavior would be for the switch to set the tag to default CS0 because the port is considered untrusted, so you're correct.
Default Voice VLAN Configuration
The voice VLAN feature is disabled by default.
When the voice VLAN feature is enabled, all untagged traffic is sent according to the default CoS priority of the port.
The CoS value is not trusted for 802.1P or 802.1Q tagged traffic.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swvoip.html
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Mike,
HTH,
John
Hi mike,
Your correct in your assumption.
If the maked  packet goes into a non enabled mls qos switch, the switch  will rewrite the marking to a cos 0
Switch#sh mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
Switch#sh mls qos int fa0/1
FastEthernet0/1
QoS is disabled. When QoS is enabled, following settings will be applied
trust state: not trusted
trust mode: not trusted
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
res
Paul
Kind Regards
Paul
have you tired  to disable DSCP rewrite with global command "no mls qos rewrite ip dscp"
