What IOS do I upgrade to??
mgar18777
I'm trying to run OSPF inside my network and I'm running Version: C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1).
Here's a "sh ver":
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
ALLEN-1.11.5-CoreSW uptime is 6 days, 5 hours, 21 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K byt
es of memory.
Processor board ID CAT1034ZHLB
Last reset from power-on
4 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:2F:B3:F2:80
Motherboard assembly number : 73-9897-06
Power supply part number : 341-0097-02
Motherboard serial number : CAT10335QW4
Power supply serial number : AZS103003HV
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-24TS-S
System serial number : CAT1034ZHLB
Top Assembly Part Number : 800-26160-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMG00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24TS 12.2(25)SEB4 C3560-IPBASE-M
I understand I need an IP Services Image. Can I upgrade to: c3560-ipservicesk9-mz.122-50.SE.bin?
If not, does anyone know which IOS file I can upgrade to, to use OSPF?
17 Replies 17
Victor,
I'm good, what about you?
After reading all comments in this thread again. Just want to give you 5P!. Not sure why though! (grin)
Toshi
Toshi! My man!
Thanks...
Im OK, man...economy here sucks big time. Work is slow...people getting laid off.
Where are you located?
Victor,
I'm from the crypton planet in which the superman was born. Just kidding(grin) I'm from Thailand(Asia). I've got problems because the economic crisis as well.
Nice to see you here.
Toshi
