What is command to enable "neighbor x.x.x.x shutdown"
wfqk
Level 5
Level 5
Hi In asr1006, the config is like this: neighbor x.x.x.x shutdown. We want to enable it. I do not think the below two are corrent:
neighbor x.x.x.x no shutdown
no neighbor x.x.x.x shutdown
How do you think about it? Thank you
Rolf Fischer
Level 9
Level 9
from the BGP Command Reference:
"To disable a neighbor or peer group or to gracefully shut down a link for maintenance, use the neighbor shutdown command in router configuration mode or address family configuration mode. To reenable the neighbor or peer group, use the no form of this command."
no neighbor { ip-address | peer-group-name } shutdown (...)
Rolf
Rolf Fischer
Level 9
Level 9
Rolf
I confirmed you are right. Thank you
