What is CPU0 in interface 0/0/CPU0 in ASR9K ?
wfqk
Level 5
Level 5
Hi Any one can tell what is CPU0 in interface 0/0/CPU0 in ASR9K ? Thank you
Reza Sharifi
Not familiar with ASR9k but it seems that each slot as a CPU.  See this link:
The following example illustrates sample output from the show canbus command with the server-stats keyword:
RP/0/RSP0/CPU0:router(admin)# show canbus server-stats location all
       Slot   State Partition-A Rev Partition-B Rev Active-Partition
   0/0/CPU0  Online            2.01            2.02      Partition B
   0/1/CPU0  Online            2.01            2.02      Partition B
Link:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-0/system_management/command/reference/yr40asr9k_chapter7.html
