What is Defect status mean from an ATM circuit?
rleung2001
my Atm port is down/down, is that mear the card has problem?
On my atm card, the defect status, LOS ( loss of signal, LOF (loss of frame ), is that indicating a physical atm card problem?
Modem Status: Showtime (DMTDSL_DLOAD_1)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'STMI' ' '
Vendor Specific: 0x0000 0x0000
Vendor Country: 0x0F 0x00
Capacity Used: 24% 72%
Noise Margin: -9.5 dB 6.0 dB
Output Power: 1.0 dBm 5.0 dBm
Attenuation: 10.0 dB 6.0 dB
Defect Status: LOS LOF LCDf LOM LOS LOF LCDf
Last Fail Code: None
Watchdog Counter: 0x79
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 118646 (0 spurious)
PHY Access Err: 0
Activations: 1
LED Status: OFF
LED On Time: 0
LED Off Time: 0
Init FW: init_AMR-R-2.5.042_no_bist.bin
Operation FW: AMR-R-2.5.042.bin
FW Source: embedded
FW Version: 2.5.42
Interleave Fast Interleave Fast
Speed (kbps): 0 2528 0 640
Cells: 0 35368625 0 2093775741
Reed-Solomon EC: 0 0 217 229
CRC Errors: 0 433 190 199
Header Errors: 0 5 177 200
Total BER: 0E-0 0E-0
Leakage Average BER: 0E-0 2E-0
paolo bevilacqua
Was the circuit working previously?
What you see indicates a problem on the ISP side where ADSL is up but no circuit is working. So you need to log a ticket with them.
If you want to be the safe side, update your ADSL FW from:
ftp://ftp.cisco.com/pub/access/800
The one you want is 3.010 or later.
hope this helps, please rate post if it does!
