What is difference between two kinds of vrf?
wfqk
Level 5
Level 5
Hi Usually when we configure mpls, we need to configure vrf, which is like below:
R3(config)#ip vrf RED
R3(config-vrf)#rd 100:3
R3(config-vrf)#route-target export 100:3
R3(config-vrf)#route-target import 100:1
But I found there is another way to create vrf below. My question is why we use the below to create vrf? Thank you
vrf context ABC
  ip route 10.10.10.5/32 10.10.64.9 name ABCDE
Peter Paluch
The first syntax with ip vrf RED is the older way of defining VRFs on IOS-based devices. The second syntax with vrf context is used on Nexus switches running NX-OS.
The ip vrf syntax on IOS is in fact deprecated because it was only supported with IPv4. The new style of VRF configuration supports both IPv4 and IPv6, and looks like this:
vrf definition RED
 address-family ipv4
 address-family ipv6
interface FastEthernet0/0
 vrf forwarding RED
Best regards,
Peter
Peter Paluch
vrf definition RED
 address-family ipv4
 address-family ipv6
 vrf forwarding RED
Best regards,
Peter
Thank you so much. I think you are right.
 vrf forwarding RED
but I still see vrf configuration for interface like below. Do you think it is the same thing?
 vrf member RED
The vrf member syntax is again used on NX-OS.
Check out this webpage - it's a fairly nice comparison of IOS and NX-OS syntax pertaining to VRFs.
http://www.netcraftsmen.com/using-vrfs-in-nx-os-compared-to-ios/
Best regards,
Peter
Excellent, thank you
