what is frame and unframe, how to check?
frankie_sky
hi all expert here, i newbie here and work in network support now.
just want to ask ...how to check the device is "frame" and "unframe"
and what is frame and unframe
thanks.
mheusinger
Level 10
Level 10
Hello Frankie,
in which context did you pick up those words?
It reminds me about an E1 interface, where you can have a framed and an unframed E1. An E1 is the European equivalent of a T1. With an E1 you have one option of using it in a 2048 kbps bit stream configuration called "unframed E1". Or you can use framing, i.e. a certain arrangement of the bits and bytes during transmission giving you 30 or 31 channels with 64 kbps each. The latter option is called a "framed E1". Depending on your hardware there are different commands to check this.
Hope this helps! Please rate all posts.
Regards, Martin
