What is Mgmt port's role?
Soon Kwan Kwon
Hello all,
I'm wondering about Mgmt port's role?..
As I know, that port is for managing ?
for example, when configuring something?
Hmmm. Please let me know the role..
Thanks for reading.
SK.
Hi SK,
There is a very good post on difference between management and console port, please see below
https://supportforums.cisco.com/discussion/12467571/difference-between-console-port-and-dedicated-management-port
Manish
- Do rate helpful posts -
Manish Gogna
Hi SK,
The purpose of this interface is to allow users to perform management tasks on the router; it is basically an interface that should not and often cannot forward network traffic but can otherwise access the router, often via Telnet and SSH, and perform most management tasks on the router.
Some useful info here
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/int_hw_components/configuration_guide/b_int_152ex_2960-x_cg/b_int_152ex_2960-x_cg_chapter_0100.html
You may search for your device model specific info as well.
Manish
Thank you Gogna,
Then,,. Do management port perform like console connection?
If I connect management port using UTP, should I configure the router?
SK.
Hi SK,
Manish
